Datasheet Texas Instruments TPS2062DRG4 — Даташит
СерияTPS2062
МодельTPS2062DRG4
Двойные 1А токоограничительные, силовые распределительные переключатели 8-SOIC -40 до 85
Current Limited, Power Distribution Switches datasheet
PDF, 1.6 Мб, Версия: I, Файл опубликован: 29 окт 2009
Package TypeD
Package QTY2500
Маркировка2062
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Continuous Current(Max)1 A
Current Limit TopologyConstant-Current
EnableActive Low
Number of Switches2
USB Switch rDS(on)70 mOhms
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS2062EVM-293
    TPS2062EVM Evaluation Module
  • Doubling the Power with Ganged TPS2062/TPS2066
    PDF, 170 Кб, Файл опубликован: 4 авг 2004
    The TPS2062/TPS2066 devices are dual-channel, 1-A, power-distribution switches that are intended for applications where heavy capacitive loads and short circuits are likely to be encountered. These devices incorporate 70-milliohm, N-channel MOSFET power switches for power-distribution systems that require multiple power switches in a single package. When output load exceeds current-limit threshold
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2062DRG4
