Datasheet Texas Instruments TPS2082DG4 — Даташит
Серия | TPS2082 |
Модель | TPS2082DG4 |
0,7 А 2,7–5,5 В Двойной (2 входа/2 выхода) переключатель MOSFET на верхней стороне, сообщение об ошибке ИС 2 Act-Low Enable 8-SOIC 0–85
Power-Distribution Switches datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 8 окт 2007
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 75 |
Carrier | TUBE |
Маркировка | 2082 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Current Limit Type | Fixed |
Current Limit(Max) | 0.5 A |
Current Limit(Min) | 0.5 A |
Fault Response | Auto Retry |
Imax | 0.5 A |
Количество каналов | 2 |
Рабочий диапазон температур | от 0 до 85 C |
Overvoltage Protection | None |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Quiescent Current (Iq)(Max) | 110 uA |
Quiescent Current (Iq)(Typ) | 85 uA |
Rise Time(Typ) | 2500 us |
Ron(Typ) | 90 mOhm |
Shutdown Current (ISD)(Typ) | 0.025 uA |
Soft Start | Fixed Rise Time |
Special Features | Active Low,Fault Reporting,Over Current Reporting,Thermal Shutdown,Under Voltage Lock Out |
UL Recognition | No |
Vabsmax(Max) | 5.5 В |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
- Managing Multiple Power Rails With the TPS208x/209xPDF, 268 Кб, Файл опубликован: 30 мар 2001
Auxiliary power (V aux) applications involve switching from one voltage source to another while maintaining uninterrupted power to the load. The Texas Instruments? TPS208x/9x family of power distribution switches are designed to manage these types of multiple-source applications. - A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2082 (4)
- TPS2082D TPS2082DG4 TPS2082DR TPS2082DRG4
- Semiconductors > Power Management > Integrated Load Switches > Voltage & Current Limit Protection
