Datasheet Texas Instruments TPS2085DRG4 — Даташит
СерияTPS2085
МодельTPS2085DRG4
0,7 А 2,7–5,5 В, четверной (4 входа/4 выхода) переключатель MOSFET на верхней стороне, сообщение об ошибке ИС 4 Act-High Enable 16-SOIC 0–85
Power-Distribution Switches datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 8 окт 2007
IC PWR SWITCH N-CHAN 1:1 16SOIC. Power Switch/Driver 1:1 N-Channel 500mA 16-SOIC. PMIC - Power Distribution Switches, Load Drivers
TPS2085DRG4
177 ₽
ТаймЧипс
TPS2085DRG4
TPS2085DRG4
Hi-Tech Circuit Group
TPS2085DRG4
Pin16
Package TypeD
Package QTY2500
Маркировка2085
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Current Limit TypeFixed
Current Limit(Max)0.5 A
Current Limit(Min)0.5 A
Fault ResponseAuto Retry
Imax0.5 A
Количество каналов4
Рабочий диапазон температурот 0 до 85 C
Overvoltage ProtectionNone
Quiescent Current (Iq)(Max)110 uA
Quiescent Current (Iq)(Typ)85 uA
Rise Time(Typ)2500 us
Ron(Typ)90 mOhm
Shutdown Current (ISD)(Typ)0.025 uA
Soft StartFixed Rise Time
Special FeaturesFault Reporting,Over Current Reporting,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionNo
Vabsmax(Max)5.5 В
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Managing Multiple Power Rails With the TPS208x/209x
    PDF, 268 Кб, Файл опубликован: 30 мар 2001
    Auxiliary power (V aux) applications involve switching from one voltage source to another while maintaining uninterrupted power to the load. The Texas Instruments? TPS208x/9x family of power distribution switches are designed to manage these types of multiple-source applications.
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2085 (4)
  • Semiconductors > Power Management > Integrated Load Switches > Voltage & Current Limit Protection
На английском языке: Datasheet Texas Instruments TPS2085DRG4
