Datasheet Texas Instruments TPS2206IDFR — Даташит
СерияTPS2206
МодельTPS2206IDFR
Dual-Slot PC Card Power-Interface Switch With Reset For Serial PCMCIA Controller datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 25 окт 2000
Статус продуктаСкоро будет снят с производства (Производитель объявил о скором прекращении производства прибора)
Pin30
Package TypeDF
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.55
3V rDS(on)(Typ)110 mOhm
5V rDS(on)(Typ)140 mOhm
Adjustable Current Limit(Min)1 A
InterfaceSerial
Package GroupHTSSOP,SSOP
Package Size: mm2:W x L32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP),30SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Ports2
Special FeaturesCurr/Temp Protection,Over Current Reporting,Supports 12V,Supports VPP
RoHSНе совместим
  • Comparison And Selecting of PC Card Power Controllers
    PDF, 102 Кб, Файл опубликован: 4 мар 2003
    With so many PC Card power controller options available from Texas Instruments, it may be somewhat difficult for designers to select a particular device. This report summarizes all of the similarities and differences, such as features and options, between all of these PC Card power controllers to help eliminate any potential confusion. With the help of this report, the designer can select an exact
Серия: TPS2206 (5)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > PCI/PCMCIA/Cardbus Switch Matrix
На английском языке: Datasheet Texas Instruments TPS2206IDFR
