Datasheet Texas Instruments OPA552UA — Даташит
СерияOPA552
МодельOPA552UA
Высоковольтные сильноточные операционные усилители 8-SOIC
OPA55x High-Voltage, High-Current Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2016
52 предложений от 24 поставщиков
Элитан
OPA552UA
459 ₽
OPA552UA
от 940 ₽
МосЧип
OPA552UA/2K5
OPA552UA/2K5
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
Маркировка552UAOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesDecompensated
АрхитектураFET
CMRR(Min)92 дБ
CMRR(Typ)102 дБ
GBW(Typ)12 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)8.5 мА
Iq per channel(Typ)7 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)380 мА
Rail-to-RailNo
Slew Rate(Typ)24 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA552UA
