Datasheet Texas Instruments OPA512BM — Даташит
СерияOPA512
МодельOPA512BM
Очень сильноточный и мощный операционный усилитель 8-TO-3
Datasheet
TSP
18 предложений от 18 поставщиков
Зенер
Россия и страны ТС
OPA512BM
28 550 ₽
Элитан
OPA512BM
35 808 ₽
SUV System
OPA512BM
OPA512BM
Package TypeLMF
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Width (мм)25.4
Length (мм)38.86
Thickness (мм)7.11
Pitch (мм)6.35
Max Height (мм)7.62
RoHSНе совместим
  • Heat Sinking- TO-3 Thermal Model
    PDF, 23 Кб, Файл опубликован: 27 сен 2000
    A critical issue with all semiconductor devices is junction temperature (TJ). TJ must be kept below its maximum rated value, typically 150В°C. The lower the junction temperature the better. The thermal circuit shown allows temperature to be estimated with simple calculations. The temperature rise across each interface is equal to the total power dissipated in the device ti
  • Mounting Considerations for TO-3 Packages
    PDF, 73 Кб, Файл опубликован: 27 сен 2000
    Proper mounting of TO-3 packages is required to assure rated performance and reliability. Although the procedures are simple, ignoring them can result in poor performance and catastrophic failure of the device.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA512 (2)
На английском языке: Datasheet Texas Instruments OPA512BM
