Datasheet Texas Instruments TPS2300IPWG4 — Даташит
Серия | TPS2300 |
Модель | TPS2300IPWG4 |
3-13 В Двойная ИС HotSwap с независимым разрывом цепи канала и отчетом о хорошем питании, включением Act-Low 20-TSSOP от -40 до 85
Dual Hot-Swap Power Controllers w/Independent Circuit Breaker & Power-Good Rep datasheet
PDF, 506 Кб, Версия: H, Файл опубликован: 10 май 2013
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 70 |
Carrier | TUBE |
Маркировка | TPS2300I |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Channel(s) Controlled | 2 |
Current Limit Accuracy | Adjustable |
Current Limit Function Enabled | Always |
Current Limit Threshold(Typ) | Adjustable Ext FET=mV |
Current Measurement Accuracy | N/A % |
Design Support | Calculation Tool,EVM |
Fault Response | Latch Off |
ON_OFF Control Input | EN/ s |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | Catalog |
Status Output | FLT/,PG |
Vabsmax_cont | 15 В |
Vin(Max) | 13 В |
Vin(Min) | 3 В |
- Evaluation Modules & Boards: TPS2301EVM-153
TPS23XX Hot Swap Power Controllers Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS2330EVM-184
TPS2330 48-V Telecom Hot Swap Evaluation Module and Interface Card
- VREG Considerations in a 5V and 3.3V System Using the TPS2300/01/10/11PDF, 537 Кб, Файл опубликован: 31 мар 2006
This application report illustrates the use of the TPS2300/2301/2310/2311 for a common dual 5-V/3.3-V application. The TPS2300/2301/2310/2311 are dual-channel, hot-swap controllers that eliminate high-frequency, hot-plug or hot-removal transients, reduce inrush current, and provide overcurrent protection. The TPS2300 family can be easily configured for 5-V/3.3-V application providing a unified inp - Low Voltage (0V-5.5V) Hot-Swap Application Using TPS2300/2301PDF, 141 Кб, Файл опубликован: 1 ноя 2001
This application note illustrates the use of the TPS2300/2301 for low voltage applications. The TPS2300/2301/2310/2311/2320/2321 are dual-channel hot-swap controllers that eliminate high-frequency hot-plug or hot-removal transients, reduce inrush current, and provide overcurrent protection. The TPS2300/2301/2310/2311/2320/2321 can be easily configured for low voltage applications and are capable o - Step-By-Step Design Approach of TPS2300/01/10/11/20/21/30/31 Hotswap ControllersPDF, 169 Кб, Файл опубликован: 23 май 2003
The TPS2300/01/10/11/20/21/30/31 hotswap controllers allow safe board insertion and removal from a live backplane. With the current-limit-setting resistor (RSET), the current limit can be set much more easily than other hotswap controllers. This report uses a simple step-by-step design approach to select the essential components and parameters for typical hotswap applications. By following the des - Power Management Solutions for Infiniband (SM) I/O ModulesPDF, 75 Кб, Файл опубликован: 20 окт 2000
InfiniBand, a scalable, modular, channel-based, switched-fabric architecture, is defined for the connection of servers with servers and with storage and networking devices. Because appropriate power management is essential for quality implementations, this report presents straightforward solutions for both high-power and low-power applications as required by the InfiniBand specification.
Серия: TPS2300 (4)
- TPS2300IPW TPS2300IPWG4 TPS2300IPWR TPS2300IPWRG4
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
