Datasheet Texas Instruments TPS2300IPWR — Даташит
СерияTPS2300
МодельTPS2300IPWR
3-13 В Двойная ИС HotSwap с независимым разрывом цепи канала и отчетом о хорошем питании, включением Act-Low 20-TSSOP от -40 до 85
Dual Hot-Swap Power Controllers w/Independent Circuit Breaker & Power-Good Rep datasheet
PDF, 506 Кб, Версия: H, Файл опубликован: 10 май 2013
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTPS2300I
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Channel(s) Controlled2
Current Limit AccuracyAdjustable
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)Adjustable Ext FET=mV
Current Measurement AccuracyN/A %
Design SupportCalculation Tool,EVM
Fault ResponseLatch Off
ON_OFF Control InputEN/ s
Package GroupTSSOP
Status OutputFLT/,PG
Vabsmax_cont15 В
Vin(Max)13 В
Vin(Min)3 В
  • Evaluation Modules & Boards: TPS2301EVM-153
    TPS23XX Hot Swap Power Controllers Evaluation Module
  • Evaluation Modules & Boards: TPS2330EVM-184
    TPS2330 48-V Telecom Hot Swap Evaluation Module and Interface Card
  • VREG Considerations in a 5V and 3.3V System Using the TPS2300/01/10/11
    PDF, 537 Кб, Файл опубликован: 31 мар 2006
    This application report illustrates the use of the TPS2300/2301/2310/2311 for a common dual 5-V/3.3-V application. The TPS2300/2301/2310/2311 are dual-channel, hot-swap controllers that eliminate high-frequency, hot-plug or hot-removal transients, reduce inrush current, and provide overcurrent protection. The TPS2300 family can be easily configured for 5-V/3.3-V application providing a unified inp
  • Low Voltage (0V-5.5V) Hot-Swap Application Using TPS2300/2301
    PDF, 141 Кб, Файл опубликован: 1 ноя 2001
    This application note illustrates the use of the TPS2300/2301 for low voltage applications. The TPS2300/2301/2310/2311/2320/2321 are dual-channel hot-swap controllers that eliminate high-frequency hot-plug or hot-removal transients, reduce inrush current, and provide overcurrent protection. The TPS2300/2301/2310/2311/2320/2321 can be easily configured for low voltage applications and are capable o
  • Step-By-Step Design Approach of TPS2300/01/10/11/20/21/30/31 Hotswap Controllers
    PDF, 169 Кб, Файл опубликован: 23 май 2003
    The TPS2300/01/10/11/20/21/30/31 hotswap controllers allow safe board insertion and removal from a live backplane. With the current-limit-setting resistor (RSET), the current limit can be set much more easily than other hotswap controllers. This report uses a simple step-by-step design approach to select the essential components and parameters for typical hotswap applications. By following the des
  • Power Management Solutions for Infiniband (SM) I/O Modules
    PDF, 75 Кб, Файл опубликован: 20 окт 2000
    InfiniBand, a scalable, modular, channel-based, switched-fabric architecture, is defined for the connection of servers with servers and with storage and networking devices. Because appropriate power management is essential for quality implementations, this report presents straightforward solutions for both high-power and low-power applications as required by the InfiniBand specification.
Серия: TPS2300 (4)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments TPS2300IPWR
