Datasheet Texas Instruments OPA548T-1 — Даташит
СерияOPA548
МодельOPA548T-1
Высоковольтный, сильноточный операционный усилитель мощности с широким размахом выходного напряжения 7-TO-220 от -40 до 85
OPA548 High-Voltage, High-Current Operational Amplifier datasheet
PDF, 3.0 Мб, Версия: C, Файл опубликован: 6 апр 2015
Pin7
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
Package QTY50
МаркировкаOPA548T
Width (мм)8.38
Length (мм)10.17
Thickness (мм)4.58
Max Height (мм)4.7
Additional FeaturesAdj Current Limit,Shutdown
АрхитектураBipolar
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)500000 pA
Iq per channel(Max)20 мА
Iq per channel(Typ)17 мА
Количество каналов1
Offset Drift(Typ)30 uV/C
Output Current(Typ)3000 мА
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Rail-to-RailIn to V-
Slew Rate(Typ)10 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Evaluation Modules & Boards: OPA548EVM
    OPA548 Evaluation Module
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer Feedback
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
OPA548T1, OPA548T 1
На английском языке: Datasheet Texas Instruments OPA548T-1
