Datasheet Texas Instruments TPS23750PWPG4 — Даташит
Серия | TPS23750 |
Модель | TPS23750PWPG4 |
IEEE 802.3af PD Controller with Integrated DC/DC 20-HTSSOP -40 to 85
Integrated 100-V IEEE 802.3af PD and DC/DC Controller datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 7 фев 2008
Купить TPS23750PWPG4 на РадиоЛоцман.Цены — от 120 до 228 ₽ 10 предложений от 10 поставщиков IC, PD & DC/DC CONTROLLER, 20-HTSSOP - More Details | |||
TPS23750PWPG4 Texas Instruments | 120 ₽ | ||
TPS23750PWPG4 Texas Instruments | 164 ₽ | ||
TPS23750PWPG4 Texas Instruments | 228 ₽ | ||
TPS23750PWPG4 Texas Instruments | по запросу |
Pin | 20 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 70 |
Carrier | TUBE |
Маркировка | TPS23750 |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
DC/DC Control | PD and DC/DC |
Fault Response | Auto Retry |
PD Power Level | 13W |
Package Group | HTSSOP |
Package Size: mm2:W x L | 20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG |
PoE Current Limit(Min) | 405 мА |
PoE Inrush Limit(Typ) | 140 мА |
PoE Standards Supported | 802.3at Type 1 (802.3af) |
Special Features | Error Amplifier,Thermal Shutdown |
Switching Frequency | Programmable |
Vin(Max) | 67 В |
rDS(on) per FET(Typ) | 600 mOhms |
- Evaluation Modules & Boards: TPS23750EVM-107
TPS23750 Evaluation Module Buck
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS23750EVM-108
TPS23750 Evaluation Module Flyback
- Bridging the Efficiency Gap in PoE Powered Device DesignsPDF, 113 Кб, Файл опубликован: 18 мар 2011
The trend toward higher efficiency is becoming increasingly evident for Power over Ethernet (PoE) applications. Powered Device (PD) suppliers are looking for solutions that enable them to market their products as being “Green” or energy efficient. All of the components within the PD’s power path need to be closely examined to see if any significant improvements in efficiency can be made. This appl - Wall Adapter Powers IEEE 802.3af Powered DevicePDF, 595 Кб, Файл опубликован: 1 фев 2006
Power-on-Ethernet is an emerging technology that allows an existing Ethernet connection to carry both data and power. However, today's powered-device (PD) designers face a dilemma - not all Ethernet connections are wired for power. To operate with these legacy connections, a PD can use a wall adapter, but this capability must be designed into the PD. - Lightning Surge Considerations for PoE Powered DevicesPDF, 197 Кб, Файл опубликован: 30 апр 2015
- Practical Guidelines EMI Compliant PoEPDF, 5.2 Мб, Файл опубликован: 27 мар 2008
Practical Guidelines to Designing an EMI Compliant PoE Powered Device with Non-Isolated DC/DC - Designing an EMI Compliant PoE with Isolated FlybackPDF, 4.6 Мб, Файл опубликован: 20 май 2008
Серия: TPS23750 (4)
- TPS23750PWP TPS23750PWPG4 TPS23750PWPR TPS23750PWPRG4
- Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
