Datasheet Texas Instruments TPS23751PWP — Даташит
Серия | TPS23751 |
Модель | TPS23751PWP |
Интерфейс PoE IEEE 802.3at и контроллер DC/DC в зеленом режиме 16-HTSSOP -40 to 85
TPS2375x IEEE 802.3at PoE Interface With Wide Range High Efficiency DC-DC Controller datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 12 ноя 2015
Pin | 16 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 90 |
Carrier | TUBE |
Маркировка | 23751 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
DC/DC Control | PD and DC/DC |
Fault Response | Auto Retry |
PD Power Level | 25W |
Package Group | HTSSOP |
Package Size: mm2:W x L | 16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG |
PoE Current Limit(Min) | 850 мА |
PoE Inrush Limit(Typ) | 140 мА |
PoE Standards Supported | 802.3at Type 1 (802.3af),802.3at Type 2 |
Special Features | Thermal Shutdown,VFO |
Switching Frequency | Programmable |
Vin(Max) | 57 В |
Vin(Min) | 9.2 В |
rDS(on) per FET(Typ) | 450 mOhms |
- Evaluation Modules & Boards: TPS23751EVM-104
TPS23751 Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS23752EVM-145
TPS23752 Evaluation Module
- High Efficiency Class 4 PoE Powered DevicePDF, 342 Кб, Файл опубликован: 23 мар 2011
This report introduces a high-efficiency, Power-over-Ethernet (PoE) Powered Device (PD) that complies with the Type 2, Class 4 power requirements outlined in the IEEE802.3at Draft 3.3 standard. The standard permits a Type 2, Class 4 PD to draw up to 25.5 W of power at the Power Interface (PI) when connected to compatible Type 2 Power Sourcing Equipment (PSE) using Type 2 compliant cabling. A fully - Advanced Adapter ORing Solutions using the TPS23753 (Rev. A)PDF, 203 Кб, Версия: A, Файл опубликован: 9 фев 2009
The TPS23753 has a number of features that simplify ORing of Power over Ethernet (PoE) and ac-powered adapters. These features are integrated into the powered device (PD) and dc/dc controller to provide an integrated solution set. This application note explores these features and provides other critical information. - Lightning Surge Considerations for PoE Powered DevicesPDF, 197 Кб, Файл опубликован: 30 апр 2015
- Designing an EMI Compliant PoE with Isolated FlybackPDF, 4.6 Мб, Файл опубликован: 20 май 2008
Серия: TPS23751 (2)
- TPS23751PWP TPS23751PWPR
- Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
