Datasheet Texas Instruments OPA541AP — Даташит
Серия | OPA541 |
Модель | OPA541AP |
Монолитный операционный усилитель высокой мощности 11-TO-220 от -25 до 85
OPA541 High Power Monolithic Operational Amplifier datasheet
PDF, 409 Кб, Версия: B, Файл опубликован: 7 апр 2015
Pin | 11 |
Package Type | KV |
Industry STD Term | TO-220 |
JEDEC Code | R-PZFM-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | OPA541AP |
Width (мм) | 10.7 |
Length (мм) | 20.02 |
Thickness (мм) | 4.5 |
Pitch (мм) | 1.7 |
Max Height (мм) | 4.62 |
Mechanical Data | Скачать |
Additional Features | Adj Current Limit |
Архитектура | FET |
CMRR(Min) | 95 дБ |
CMRR(Typ) | 113 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 25 мА |
Iq per channel(Typ) | 20 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 15 uV/C |
Рабочий диапазон температур | от -25 до 85 C |
Output Current(Typ) | 10000 мА |
Package Group | TO-220 |
Package Size: mm2:W x L | See datasheet (TO-220) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 10 V/us |
Total Supply Voltage(Max) | 70 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 20 +5V=5, +/-5V=10 |
Vos (Offset Voltage @ 25C)(Max) | 1 мВ |
- Evaluation Modules & Boards: OPAMPEVM
Universal Operational Amplifier Evaluation Module
- Improve OPA541 Current-Limit StabilityPDF, 31 Кб, Файл опубликован: 2 окт 2000
OPA541 is the industry's highest performance monolithic power amplifier. It can operate on В±40V power supplies and put out 5A continuously (10A peak). Internal current-limit circuitry can be user-programmed with a single external resistor to protect the amplifier and load from fault conditions. - Mounting Considerations for TO-3 PackagesPDF, 73 Кб, Файл опубликован: 27 сен 2000
Proper mounting of TO-3 packages is required to assure rated performance and reliability. Although the procedures are simple, ignoring them can result in poor performance and catastrophic failure of the device. - MTTF, Failrate, Reliability, and Life TestingPDF, 51 Кб, Файл опубликован: 4 окт 2000
At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr - Power Amplifier Stress and Power Handling LimitationsPDF, 55 Кб, Файл опубликован: 27 сен 2000
To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA541 (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
