Datasheet Texas Instruments TPS2375PWR — Даташит
СерияTPS2375
МодельTPS2375PWR
Контроллеры устройств с питанием PoE IEEE 802.3af 8-TSSOP -40 to 85
TPS237x: IEEE 802.3af PoE Powered Device Controllers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 25 апр 2008
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка2375
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
DC/DC ControlPD Only
Fault ResponseLatch
PD Power Level13W
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
PoE Current Limit(Min)405 мА
PoE Inrush Limit(Typ)Programmable мА
PoE Standards Supported802.3at Type 1 (802.3af)
Special FeaturesPG,Programmable UVLO,Thermal Shutdown
Vin(Max)57 В
rDS(on) per FET(Typ)580 mOhms
  • Evaluation Modules & Boards: TPS2375EVM
    TPS2375 IEEE802.3af POE Powered Device Evaluation Module
  • Practical Guidelines EMI Compliant PoE
    PDF, 5.2 Мб, Файл опубликован: 27 мар 2008
    Practical Guidelines to Designing an EMI Compliant PoE Powered Device with Non-Isolated DC/DC
  • Designing an EMI Compliant PoE with Isolated Flyback
    PDF, 4.6 Мб, Файл опубликован: 20 май 2008
  • 25-W, High-Power PoE Using the TPS2376-H
    PDF, 958 Кб, Файл опубликован: 13 окт 2006
    This document describes the characteristics, operation, and use of reference design PR567A demonstrating high-power Power-over-Ethernet (PoE). Typical PoE applications consist of two parts: 1) power sourcing equipment (PSE) that injects power into the Ethernet Category 5 (CAT5) cable and 2) powered devices (PD) that connect to the CAT5 cable to receive power. This reference design demonstrates a c
  • Using Standard Power-Over-Ethernet Controllers for High-Powered Devices
    PDF, 65 Кб, Файл опубликован: 7 апр 2006
  • Powered Device Controllers Comparison
    PDF, 217 Кб, Файл опубликован: 22 апр 2004
    Two generations of powered device (PD) controllers are available from Texas Instruments for Power-over-Ethernet PD solutions. They are the TPS2370/TPS2371 and the TPS2375/TPS2377. While they are largely pin-compatible, some differences between these two families of PD controllers make the TPS2375 and TPS2377 the preferred devices. This report explains the major differences between the two families
  • Wall Adapter Powers IEEE 802.3af Powered Device
    PDF, 595 Кб, Файл опубликован: 1 фев 2006
    Power-on-Ethernet is an emerging technology that allows an existing Ethernet connection to carry both data and power. However, today's powered-device (PD) designers face a dilemma - not all Ethernet connections are wired for power. To operate with these legacy connections, a PD can use a wall adapter, but this capability must be designed into the PD.
  • High Power PoE PD Using the TPS2375/77-1
    PDF, 781 Кб, Файл опубликован: 28 фев 2006
    Some specialized applications require more power than 12.95 W allowed by the IEEE802.3af standard. This application report discusses techniques for implementing nonstandard high-power systems with an emphasis on the powered device (PD). A specific design example of a 27-W, two-pair PD front end is presented along with test results. This type of solution bridges between the existing IEEE 802.3af a
  • Lightning Surge Considerations for PoE Powered Devices
    PDF, 197 Кб, Файл опубликован: 30 апр 2015
  • Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
На английском языке: Datasheet Texas Instruments TPS2375PWR
