Datasheet Texas Instruments TPS2376DDAR-H — Даташит
Серия | TPS2376-H |
Модель | TPS2376DDAR-H |
IEEE 802.3af PoE HIGH POWER PD CONTROLLER 8-SO PowerPAD -40 to 85
IEEE 802.3af PoE High Power PD Controller datasheet
PDF, 970 Кб, Версия: A, Файл опубликован: 25 сен 2006
Купить TPS2376DDAR-H на РадиоЛоцман.Цены — от 79 до 421 ₽ 17 предложений от 13 поставщиков Power Over Ethernet PD Controller 0V 57V 26W 8Pin HSOP EP | |||
TPS2376DDAR-H Texas Instruments | 79 ₽ | ||
TPS2376DDAR-H Texas Instruments | 101 ₽ | ||
TPS2376DDAR-H Texas Instruments | 262 ₽ | ||
TPS2376DDAR-H Texas Instruments | по запросу |
Pin | 8 |
Package Type | DDA |
Industry STD Term | HSOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2376H |
Width (мм) | 3.9 |
Length (мм) | 4.89 |
Thickness (мм) | 1.48 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.7 |
Mechanical Data | Скачать |
DC/DC Control | PD Only |
Fault Response | Auto Retry |
PD Power Level | 25W |
Package Group | SO PowerPAD |
Package Size: mm2:W x L | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG |
PoE Current Limit(Min) | 625 мА |
PoE Inrush Limit(Typ) | Programmable мА |
PoE Standards Supported | 802.3at Type 1 (802.3af) |
Special Features | PG,Programmable UVLO,Thermal Shutdown |
Vin(Max) | 57 В |
rDS(on) per FET(Typ) | 580 mOhms |
- Evaluation Modules & Boards: TPS2376HEVM
TPS2376H Evaluation Module
- Current balancing in four-pair, high-power PoE applicationsPDF, 269 Кб, Файл опубликован: 18 май 2007
- High Power PoE PD Using the TPS2375/77-1PDF, 781 Кб, Файл опубликован: 28 фев 2006
Some specialized applications require more power than 12.95 W allowed by the IEEE802.3af standard. This application report discusses techniques for implementing nonstandard high-power systems with an emphasis on the powered device (PD). A specific design example of a 27-W, two-pair PD front end is presented along with test results. This type of solution bridges between the existing IEEE 802.3af a - Lightning Surge Considerations for PoE Powered DevicesPDF, 197 Кб, Файл опубликован: 30 апр 2015
- Wall Adapter Powers IEEE 802.3af Powered DevicePDF, 595 Кб, Файл опубликован: 1 фев 2006
Power-on-Ethernet is an emerging technology that allows an existing Ethernet connection to carry both data and power. However, today's powered-device (PD) designers face a dilemma - not all Ethernet connections are wired for power. To operate with these legacy connections, a PD can use a wall adapter, but this capability must be designed into the PD.
Серия: TPS2376-H (4)
- TPS2376DDA-H TPS2376DDA-HG4 TPS2376DDAR-H TPS2376DDAR-HG4
- Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
TPS2376DDARH, TPS2376DDAR H
