Datasheet Texas Instruments TPS2377DR — Даташит
Серия | TPS2377 |
Модель | TPS2377DR |
Контроллеры устройств с питанием PoE IEEE 802.3af 8-SOIC -40 до 85
TPS237x: IEEE 802.3af PoE Powered Device Controllers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 25 апр 2008
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2377 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
DC/DC Control | PD Only |
Fault Response | Latch |
PD Power Level | 13W |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
PoE Current Limit(Min) | 405 мА |
PoE Inrush Limit(Typ) | Programmable мА |
PoE Standards Supported | 802.3at Type 1 (802.3af) |
Special Features | PG,Programmable UVLO,Thermal Shutdown |
Vin(Max) | 57 В |
rDS(on) per FET(Typ) | 580 mOhms |
- Evaluation Modules & Boards: TPS2375EVM
TPS2375 IEEE802.3af POE Powered Device Evaluation Module
- Practical Guidelines EMI Compliant PoEPDF, 5.2 Мб, Файл опубликован: 27 мар 2008
Practical Guidelines to Designing an EMI Compliant PoE Powered Device with Non-Isolated DC/DC - Designing an EMI Compliant PoE with Isolated FlybackPDF, 4.6 Мб, Файл опубликован: 20 май 2008
- High Power PoE PD Using the TPS2375/77-1PDF, 781 Кб, Файл опубликован: 28 фев 2006
Some specialized applications require more power than 12.95 W allowed by the IEEE802.3af standard. This application report discusses techniques for implementing nonstandard high-power systems with an emphasis on the powered device (PD). A specific design example of a 27-W, two-pair PD front end is presented along with test results. This type of solution bridges between the existing IEEE 802.3af a - 25-W, High-Power PoE Using the TPS2376-HPDF, 958 Кб, Файл опубликован: 13 окт 2006
This document describes the characteristics, operation, and use of reference design PR567A demonstrating high-power Power-over-Ethernet (PoE). Typical PoE applications consist of two parts: 1) power sourcing equipment (PSE) that injects power into the Ethernet Category 5 (CAT5) cable and 2) powered devices (PD) that connect to the CAT5 cable to receive power. This reference design demonstrates a c - Powered Device Controllers ComparisonPDF, 217 Кб, Файл опубликован: 22 апр 2004
Two generations of powered device (PD) controllers are available from Texas Instruments for Power-over-Ethernet PD solutions. They are the TPS2370/TPS2371 and the TPS2375/TPS2377. While they are largely pin-compatible, some differences between these two families of PD controllers make the TPS2375 and TPS2377 the preferred devices. This report explains the major differences between the two families - Lightning Surge Considerations for PoE Powered DevicesPDF, 197 Кб, Файл опубликован: 30 апр 2015
Серия: TPS2377 (6)
- TPS2377D TPS2377DG4 TPS2377DR TPS2377DRG4 TPS2377PW TPS2377PWR
- Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
