Datasheet Texas Instruments TPS2377DR-1G4 — Даташит
Серия | TPS2377-1 |
Модель | TPS2377DR-1G4 |
Контроллеры устройств с питанием PoE IEEE 802.3af 8-SOIC -40 до 85
IEEE 802.3af PoE Powered Device Controllers With Auto-Retry datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 25 апр 2008
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2377-1 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
DC/DC Control | PD Only |
Fault Response | Auto Retry |
PD Power Level | 13W |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
PoE Current Limit(Min) | 405 мА |
PoE Inrush Limit(Typ) | Programmable мА |
PoE Standards Supported | 802.3at Type 1 (802.3af) |
Special Features | PG,Programmable UVLO,Thermal Shutdown |
Vin(Max) | 57 В |
rDS(on) per FET(Typ) | 580 mOhms |
- High Power PoE PD Using the TPS2375/77-1PDF, 781 Кб, Файл опубликован: 28 фев 2006
Some specialized applications require more power than 12.95 W allowed by the IEEE802.3af standard. This application report discusses techniques for implementing nonstandard high-power systems with an emphasis on the powered device (PD). A specific design example of a 27-W, two-pair PD front end is presented along with test results. This type of solution bridges between the existing IEEE 802.3af a - Designing an EMI Compliant PoE with Isolated FlybackPDF, 4.6 Мб, Файл опубликован: 20 май 2008
- Practical Guidelines EMI Compliant PoEPDF, 5.2 Мб, Файл опубликован: 27 мар 2008
Practical Guidelines to Designing an EMI Compliant PoE Powered Device with Non-Isolated DC/DC
Серия: TPS2377-1 (4)
- TPS2377D-1 TPS2377D-1G4 TPS2377DR-1 TPS2377DR-1G4
- Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
TPS2377DR1G4, TPS2377DR 1G4
