Datasheet Texas Instruments TPS2377PW — Даташит
СерияTPS2377
МодельTPS2377PW
Контроллеры устройств с питанием PoE IEEE 802.3af 8-TSSOP -40 to 85
TPS237x: IEEE 802.3af PoE Powered Device Controllers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 25 апр 2008
Package TypePW
Industry STD TermTSSOP
Package QTY150
Маркировка2377
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
DC/DC ControlPD Only
Fault ResponseLatch
PD Power Level13W
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
PoE Current Limit(Min)405 мА
PoE Inrush Limit(Typ)Programmable мА
PoE Standards Supported802.3at Type 1 (802.3af)
Special FeaturesPG,Programmable UVLO,Thermal Shutdown
Vin(Max)57 В
rDS(on) per FET(Typ)580 mOhms
  • Evaluation Modules & Boards: TPS2375EVM
    TPS2375 IEEE802.3af POE Powered Device Evaluation Module
  • 25-W, High-Power PoE Using the TPS2376-H
    PDF, 958 Кб, Файл опубликован: 13 окт 2006
    This document describes the characteristics, operation, and use of reference design PR567A demonstrating high-power Power-over-Ethernet (PoE). Typical PoE applications consist of two parts: 1) power sourcing equipment (PSE) that injects power into the Ethernet Category 5 (CAT5) cable and 2) powered devices (PD) that connect to the CAT5 cable to receive power. This reference design demonstrates a c
  • Powered Device Controllers Comparison
    PDF, 217 Кб, Файл опубликован: 22 апр 2004
    Two generations of powered device (PD) controllers are available from Texas Instruments for Power-over-Ethernet PD solutions. They are the TPS2370/TPS2371 and the TPS2375/TPS2377. While they are largely pin-compatible, some differences between these two families of PD controllers make the TPS2375 and TPS2377 the preferred devices. This report explains the major differences between the two families
  • Lightning Surge Considerations for PoE Powered Devices
    PDF, 197 Кб, Файл опубликован: 30 апр 2015
  • Practical Guidelines EMI Compliant PoE
    PDF, 5.2 Мб, Файл опубликован: 27 мар 2008
    Practical Guidelines to Designing an EMI Compliant PoE Powered Device with Non-Isolated DC/DC
  • Designing an EMI Compliant PoE with Isolated Flyback
    PDF, 4.6 Мб, Файл опубликован: 20 май 2008
Серия: TPS2377 (6)
  • Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Powered Device
На английском языке: Datasheet Texas Instruments TPS2377PW
