Datasheet Texas Instruments TPS23861PWR — Даташит
СерияTPS23861
МодельTPS23861PWR
Контроллер питания PSE QUAD IEEE 802.3at Power-Over-Ethernet 28-TSSOP -40 to 125
TPS23861 IEEE 802.3at Quad Port Power-over-Ethernet PSE Controller datasheet
PDF, 2.0 Мб, Версия: G, Файл опубликован: 4 окт 2016
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTPS23861PW
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
FETExternal
ICUTProgrammable
ILIMProgrammable
MPS MethodDC Disconnect
No. of PSE Ports4
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Pair ControlAlternative A
PoE Standards Supported802.3at Type 2
Special FeaturesAutonomous Mode,Current Limit with Foldback,Multi Level Port Priority,Over Current Reporting,Over Temp Reporting
Vin(Max)57 В
Vin(Min)44 В
  • Evaluation Modules & Boards: TPS23861EVM-612
    TPS23861EVM-612 Evaluation Module for Quad IEEE 802.3at PoE PSE Controller
  • University of New Hampshire Interoperability Lab Interoperability Test, TPS23861
    PDF, 916 Кб, Файл опубликован: 11 июн 2014
    Test results from the PSE interoperability test performed on the TPS23861.
  • University of New Hampshire Interoperability Lab Conformance Test, TPS23861
    PDF, 1.7 Мб, Файл опубликован: 25 апр 2014
    Clause #33 PSE conformance testing performed on the TPS23861EVM-613.
  • TPS23861 Power-On Considerations
    PDF, 104 Кб, Файл опубликован: 21 июл 2015
    TPS23861 is an IEEE 802.3at compliant PSE controller containing both analog and digital circuits as well as an embedded processor. The VPWR pin supplies power to the internal analog circuits while the VDD pin supplies power for the digital circuitry and processor. Each power supply pin monitors input voltage and creates an internal power on reset for the internal circuits. Additionally, the
  • SIFOs 802.3at Conformance Report, v 4.0.77, TPS23861
    PDF, 61 Кб, Файл опубликован: 11 июн 2014
  • Lightning Surge Considerations for PoE Power Sourcing Equipment Devices
    PDF, 1.0 Мб, Файл опубликован: 20 фев 2017
    This report considers the implementation of lightning surge protection for Power over Ethernet(PoE)powered sourcing equipment(PSE)applications. The necessity for implementing such protection will normally depend on the environment in which the PSE is intended to operate and the inherent isolation properties of the PSE. There are numerous compliance standards to consider when establishing the sur
  • TPS23861 VDD Power Solutions
    PDF, 64 Кб, Файл опубликован: 24 авг 2016
    TPS23861 is an IEEE 802.3at compliant PSE controller integrated with analog circuits, digital circuits and an embedded processor. The VPWR pin supplies power to the internal analog circuits while the VDD pin supplies power for the digital circuits and internal processor. In most applications, an extra 3.3 V power is required for VDD. This paper introduces some VDD power supply solutions and design
Серия: TPS23861 (2)
  • Semiconductors > Power Management > Power Over Ethernet (PoE)/LAN Solutions > Power Sourcing Equipment
На английском языке: Datasheet Texas Instruments TPS23861PWR
