Datasheet Texas Instruments TPS2391DGKR — Даташит
СерияTPS2391
МодельTPS2391DGKR
Простой контроллер горячей замены -48 В 8-VSSOP -40 до 85
Simple -48-V Hot Swap Controller datasheet
PDF, 696 Кб, Версия: D, Файл опубликован: 9 янв 2008
Package TypeDGK
Industry STD TermVSSOP
Package QTY2500
Маркировка2391
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Channel(s) Controlled1
Current Limit Accuracy39.5 mV +/- 16.5%
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)39.5 Ext FET=mV
Current Measurement AccuracyN/A %
Design SupportCalculation Tool,EVM,Reference Design
Fault ResponseAuto Retry
ON_OFF Control InputEN s
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Status OutputFLT/
Vabsmax_cont-100 В
Vin(Max)-36 В
Vin(Min)-80 В
  • Evaluation Modules & Boards: TPS2391EVM
    Simple -48V Hot Swap Controller EVM
  • A Universal Telecommunications Hot Swap Device Family
    PDF, 162 Кб, Файл опубликован: 14 янв 2003
    This application note describes how to design a controlled current hot swap circuit with the Texas Instruments TPS2390 family of hot swap power managers.
  • A Comparison of Telecom Hot Swap Managers TPS2398/99 vs TPS2390/91 (Rev. A)
    PDF, 88 Кб, Версия: A, Файл опубликован: 9 янв 2008
  • Hot Swap Performance Comparison
    PDF, 279 Кб, Файл опубликован: 20 июн 2003
    Various integrated circuit controllers are currently available for implementing hot swap in telecommunication (nominal ?48-V supply) systems. Two such device types are the TPS239x series and the LT1640A series. Devices from each family were placed in appropriate application circuits and exercised in different application scenarios that may typically be encountered in a working system. Comparison o
Серия: TPS2391 (4)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments TPS2391DGKR
