Datasheet Texas Instruments TPS2411PW — Даташит
СерияTPS2411
МодельTPS2411PW
Контроллер шины питания N+1 и OR-ing 14-TSSOP -40 to 85
Datasheet TPS2410, TPS2411
PDF, 1.4 Мб, Версия: C, Файл опубликован: 1 июн 2009, Страниц: 32
Full Feaured N+1 and ORing Power Rail Controller
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаTPS2411
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Channel(s) Controlled1
Design SupportEVM,Reference Design
IGate Pulsed(Typ)2.35 A
IGate Sink(Typ)5 мА
IGate Source(Max)350 uA
IGate Source(Typ)293 uA
Iq(Max)7.0 мА
Iq(Typ)1.2 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Special FeaturesInput Filter,MUX Control
VGS(Max)11.5 В
VSense Reverse(Typ)Adjustable мВ
Vabsmax(Max)18 В
Vabsmin(Min)-0.3 В
Vin(Max)16.5 В
Vin(Min)0.8 В
  • Evaluation Modules & Boards: TPS2410EVM
    TPS2410 Evaluation Module
  • Evaluation Modules & Boards: TPS2411EVM
    TPS2411 Evaluation Module
  • Minimizing Light Load Oscillations with ORing Controllers
    PDF, 81 Кб, Файл опубликован: 23 июн 2009
    ORing controllers are used to replace diodes in applications looking to improve system efficiency. They are designed to behave like a diode as much as possible. However, at light loads, with low RDS(on) FET’s, ORing controllers can create an oscillation on the rail that not only creates ripple at the output, but will also lower light load efficiency. This application note suggests a simple method
  • High Voltage ORing with Low Voltage Controllers
    PDF, 220 Кб, Файл опубликован: 30 сен 2008
  • Operational Differences of the TPS241x
    PDF, 110 Кб, Файл опубликован: 13 фев 2007
    This application note gives an overview of the operation of the TPS2410/12 and TPS2411/13. It describeshow each device controls an external N-channel MOSFET to emulate an ideal diode. It does not addressthe other pin functions of the TPS2410/11, UV and OV inputs, filtering, or the status outputs.
Серия: TPS2411 (4)
  • Semiconductors > Power Management > ORing and Smart Diodes
На английском языке: Datasheet Texas Instruments TPS2411PW
