Datasheet Texas Instruments TPS2412DRG4 — Даташит
Серия | TPS2412 |
Модель | TPS2412DRG4 |
Контроллер шины питания N+1 и OR-ing 8-SOIC -40 до 85
TPS241x N+1 and ORing Power Rail Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 23 ноя 2015
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2412D |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Channel(s) Controlled | 1 |
Design Support | EVM,Reference Design |
IGate Pulsed(Typ) | 2.35 A |
IGate Sink(Typ) | 5 мА |
IGate Source(Max) | 350 uA |
IGate Source(Typ) | 292 uA |
Iq(Max) | 7.0 мА |
Iq(Typ) | 1.2 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
VGS(Max) | 11.5 В |
VSense Reverse(Typ) | Adjustable мВ |
Vabsmax(Max) | 18 В |
Vabsmin(Min) | -0.3 В |
Vin(Max) | 16.5 В |
Vin(Min) | 0.8 В |
- Evaluation Modules & Boards: TPS2413EVM
TPS2413 Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS2412EVM
TPS2412 Evaluation Module
- Current Sharing in Redundant SystemsPDF, 237 Кб, Файл опубликован: 8 янв 2010
- Minimizing Light Load Oscillations with ORing ControllersPDF, 81 Кб, Файл опубликован: 23 июн 2009
ORing controllers are used to replace diodes in applications looking to improve system efficiency. They are designed to behave like a diode as much as possible. However, at light loads, with low RDS(on) FET’s, ORing controllers can create an oscillation on the rail that not only creates ripple at the output, but will also lower light load efficiency. This application note suggests a simple method - High Voltage ORing with Low Voltage ControllersPDF, 220 Кб, Файл опубликован: 30 сен 2008
- Operational Differences of the TPS241xPDF, 110 Кб, Файл опубликован: 13 фев 2007
This application note gives an overview of the operation of the TPS2410/12 and TPS2411/13. It describeshow each device controls an external N-channel MOSFET to emulate an ideal diode. It does not addressthe other pin functions of the TPS2410/11, UV and OV inputs, filtering, or the status outputs.
Серия: TPS2412 (10)
- Semiconductors > Power Management > ORing and Smart Diodes
