Datasheet Texas Instruments TPS2412PWG4 — Даташит
СерияTPS2412
МодельTPS2412PWG4
Контроллер шины питания N+1 и OR-ing 8-TSSOP -40 до 85
TPS241x N+1 and ORing Power Rail Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 23 ноя 2015
Package TypePW
Industry STD TermTSSOP
Package QTY150
Маркировка2412
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Channel(s) Controlled1
Design SupportEVM,Reference Design
IGate Pulsed(Typ)2.35 A
IGate Sink(Typ)5 мА
IGate Source(Max)350 uA
IGate Source(Typ)292 uA
Iq(Max)7.0 мА
Iq(Typ)1.2 мА
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
VGS(Max)11.5 В
VSense Reverse(Typ)Adjustable мВ
Vabsmax(Max)18 В
Vabsmin(Min)-0.3 В
Vin(Max)16.5 В
Vin(Min)0.8 В
  • Evaluation Modules & Boards: TPS2413EVM
    TPS2413 Evaluation Module
  • Evaluation Modules & Boards: TPS2412EVM
    TPS2412 Evaluation Module
  • Current Sharing in Redundant Systems
    PDF, 237 Кб, Файл опубликован: 8 янв 2010
  • Minimizing Light Load Oscillations with ORing Controllers
    PDF, 81 Кб, Файл опубликован: 23 июн 2009
    ORing controllers are used to replace diodes in applications looking to improve system efficiency. They are designed to behave like a diode as much as possible. However, at light loads, with low RDS(on) FET’s, ORing controllers can create an oscillation on the rail that not only creates ripple at the output, but will also lower light load efficiency. This application note suggests a simple method
  • High Voltage ORing with Low Voltage Controllers
    PDF, 220 Кб, Файл опубликован: 30 сен 2008
  • Operational Differences of the TPS241x
    PDF, 110 Кб, Файл опубликован: 13 фев 2007
    This application note gives an overview of the operation of the TPS2410/12 and TPS2411/13. It describeshow each device controls an external N-channel MOSFET to emulate an ideal diode. It does not addressthe other pin functions of the TPS2410/11, UV and OV inputs, filtering, or the status outputs.
  • Semiconductors > Power Management > ORing and Smart Diodes
На английском языке: Datasheet Texas Instruments TPS2412PWG4
