Datasheet Texas Instruments TPS2420RSAT — Даташит
СерияTPS2420
МодельTPS2420RSAT
20V, 5A, 33mО© eFuse with Dual Fault Threshold, IMON and PG 16-QFN -40 to 125
TPS2420 5-A, 20-V Integrated FET Hot-Swap Controller datasheet
PDF, 1.7 Мб, Версия: F, Файл опубликован: 29 янв 2014
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаTPS2420
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Channel(s) Controlled1
Current Limit Accuracy+/-20%
Current Limit Function EnabledAlways
Current Limit TypeAdjustable
Current Limit(Max)5 A
Current Limit(Min)1 A
FET ProtectionSOA,Thermal
Fault ResponseAuto Retry,Latch Off
Imax5 A
Количество каналов1
ON_OFF Control InputEN/ s
Overcurrent ResponseCurrent Limiting
Overvoltage ResponseN/A
Package GroupQFN
Package Size: mm2:W x L16QFN: 16 mm2: 4 x 4(QFN) PKG
Rise Time(Typ)2500 us
Ron(Typ)30 mOhm
Special FeaturesCurrent Sense/Monitor,Fault Reporting,Power Good,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionYes
Vabsmax_cont25 В
Vin(Max)20 В
Vin(Min)3 В
  • Evaluation Modules & Boards: TPS2420EVM-01
    TPS2420 Hot Swap Controller Evaluation Module
Серия: TPS2420 (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS2420RSAT
