Datasheet Texas Instruments TPS2491DGSG4 — Даташит
СерияTPS2491
МодельTPS2491DGSG4
Повторите положительный высоковольтный контроллер ограничения мощности горячей замены 10-VSSOP -40 до 85
TPS249x Positive High-Voltage Power-Limiting Hot Swap Controller datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 28 фев 2017
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаBIX
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Channel(s) Controlled1
Current Limit Accuracy50 mV +/- 10%
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)50 Ext FET=mV
Current Measurement AccuracyN/A %
Design SupportCalculation Tool,EVM,Simulation Model,WEBENCH Design
FET ProtectionSOA
Fault ResponseAuto Retry
ON_OFF Control InputEN s
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Status OutputPG
Vabsmax_cont100 В
Vin(Max)80 В
Vin(Min)9 В
  • Evaluation Modules & Boards: TPS2491EVM-002
    TPS2491 Evaluation Module
  • Evaluation Modules & Boards: LM5069EVM-627
    LM5069EVM-627 High Voltage Reverse Hookup Reverse Current Hotswap Evaluation Module
  • Using Hot-Swap Controllers for Reverse Powering FTT
    PDF, 3.3 Мб, Файл опубликован: 28 апр 2015
  • TPS2490, Reverse Input Voltage Block
    PDF, 56 Кб, Файл опубликован: 23 июн 2009
    If the input voltage to a TPS249X controlled system is reversed, The TPS249X will bedestroyed and the load will be exposed to the reverse voltage. This app note proposesa solution for both. A schematic is shown and design consideration noted for each pin.
  • Hotswap Design Using TPS2490/91 and MOSFET Transient Thermal Response
    PDF, 339 Кб, Файл опубликован: 21 июл 2004
    Hotswap circuits rely on the thermal capacitance of the series-limiting MOSFET to dissipate the large transient energy under current- or power-limit operation. The peakjunction temperature must be controlled in order to achieve a robust design. The constant-power MOSFET protection of the TPS2490 provides a simple method to useinformation provided by MOSFET manufacturers to determine peak junct
  • Selecting Transistors for Hot-swap Applications
    PDF, 500 Кб, Файл опубликован: 16 дек 2009
    In hot-swap circuits, series-limiting devices such as MOSFETs are used to control start-up inrush and fault currents. During these transient events, the MOSFET dissipates power greater than steady-state and can well exceed the thermal limits of the MOSFET. These factors require consideration when selecting the MOSFET. This application report describes the steps required to properly choose a M
  • Undervoltage and Overvoltage Control for the TPS2490/91 (Rev. A)
    PDF, 63 Кб, Версия: A, Файл опубликован: 7 окт 2008
    This application note provides a simple circuit for adding undervoltage and overvoltage control to the TPS2490 and TPS2491 hotswap controllers.
  • Hot Plug Express Card
    PDF, 99 Кб, Файл опубликован: 23 сен 2005
  • Surge Stopping and Reverse Voltage Protection with the LM5069
    PDF, 393 Кб, Файл опубликован: 11 апр 2013
    Many automotive and industrial applications require protection from a wide range of input supply insertion errors and voltage surges. Automotive voltage rails can exceed 40V during a load dump event, and at the same time, protection circuitry can encounter negative voltage surges below -24V during a reversal of the battery polarities. Several devices are available to block or clamp these events, h
Серия: TPS2491 (4)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments TPS2491DGSG4
