Datasheet Texas Instruments TPS2493PW — Даташит
СерияTPS2493
МодельTPS2493PW
Контроллер ограничения мощности высокого напряжения с возможностью горячей замены и аналоговым выходом монитора тока 14-TSSOP -40 до 125
Positive High-Voltage Power-Limiting Hotswap Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 15 янв 2013
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаTPS2493
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Channel(s) Controlled1
Current Limit Accuracy50 mV +/- 10%
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)50 Ext FET=mV
Current Measurement Accuracy+/-5 %
Design SupportCalculation Tool,EVM,Simulation Model
FET ProtectionSOA
Fault ResponseAuto Retry
ON_OFF Control InputEN s
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Special FeaturesAnalog IMON Output
Status OutputPG
Vabsmax_cont100 В
Vin(Max)80 В
Vin(Min)9 В
  • Evaluation Modules & Boards: TPS2493EVM-002
    TPS2493 Hot Swap Controller Evaluation Module for Positive 12V Rails
  • Evaluation Modules & Boards: TPS2493EVM-004
    TPS2493 Hot Swap Controller Evaluation Module for Positive 48V Rails
  • Evaluation Modules & Boards: LM5069EVM-627
    LM5069EVM-627 High Voltage Reverse Hookup Reverse Current Hotswap Evaluation Module
  • Surge Stopping and Reverse Voltage Protection with the LM5069
    PDF, 393 Кб, Файл опубликован: 11 апр 2013
    Many automotive and industrial applications require protection from a wide range of input supply insertion errors and voltage surges. Automotive voltage rails can exceed 40V during a load dump event, and at the same time, protection circuitry can encounter negative voltage surges below -24V during a reversal of the battery polarities. Several devices are available to block or clamp these events, h
Серия: TPS2493 (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments TPS2493PW
