Datasheet Texas Instruments TPS2500DRCR — Даташит
СерияTPS2500
МодельTPS2500DRCR
Интегрированный USB-выключатель питания с повышающим преобразователем 10-VSON -40 в 85
INTEGRATED USB POWER SWITCH WITH BOOST CONVERTER datasheet
PDF, 2.0 Мб, Версия: C, Файл опубликован: 23 авг 2010
Pin1010
Package TypeDRCDRC
Industry STD TermVSONVSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаCHOUCHO
Width (мм)33
Length (мм)33
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Boost Switch Current Limit (typ)4.5 A
Continuous Current(Max)1.4 A
Current Limit0.13 to 1.4 A
Current Limit Accuracy @ 1.4A+/-20 %
Current Limit TopologyConstant-Current
Eco-Mode Light-Load EfficiencyEnabled
EnableActive High
Iout @ Vin=3V (max)1.15 A
Number of Switches1
Package GroupVSON
Package Size: mm2:W x L10VSON: 9 mm2: 3 x 3(VSON) PKG
Switching Frequency(Typ)1000 kHz
USB Switch rDS(on)50 mOhms
Vin(Max)5.25 В
Vin(Min)1.8 В
  • Evaluation Modules & Boards: TPS2500EVM-337
    Power-Distribution Switch with Low Voltage Input Evaluation Module for TPS2500
  • Evaluation Modules & Boards: TPS65986EVM
    TPS65986 USB Type-C & USB PD Controller & Power Switch Evaluation Module
  • Evaluation Modules & Boards: USB-CTM-MINIDK-EVM
    USB Type-Cв„ў Minidock Board With Video and Charging Support Evaluation Module
  • Evaluation Modules & Boards: TPS65981EVM
    TPS65981 USB Type-C and USB PD Controller, Power Switch, and High Speed Multiplexer EVM
Серия: TPS2500 (2)
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Switch with Boost Converter
На английском языке: Datasheet Texas Instruments TPS2500DRCR
