Datasheet Texas Instruments TPS25921AD — Даташит
СерияTPS25921A
МодельTPS25921AD
18V, 1.6A, 90mО© eFuse with Adjustable +/-2% Accurate Current Limit 8-SOIC -40 to 85
TPS25921x 4.5V - 18V eFuse with Precise Current Limit and Over Voltage Protection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 ноя 2015
Package TypeD
Package QTY75
Маркировка25921A
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Channel(s) Controlled1
Current Limit Accuracy+/-2%
Current Limit Function EnabledAlways
Current Limit TypeAdjustable
Current Limit(Max)1.6 A
Current Limit(Min)0.4 A
FET ProtectionThermal
Fault ResponseAuto Retry
Imax1.6 A
Количество каналов1
ON_OFF Control InputENUV,OV s
Overcurrent ResponseCurrent Limiting
Overvoltage ResponseCutoff
Rise Time(Typ)260 us
Ron(Typ)90 mOhm
Special FeaturesFault Reporting,Overvoltage Protection,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionYes
Vabsmax_cont20 В
Vin(Max)18 В
Vin(Min)4.5 В
  • Evaluation Modules & Boards: TPS25921EVM-637
    TPS25921EVM-637 4.5-18V eFuse with Precision Current Limit Evaluation Module
Серия: TPS25921A (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS25921AD
