Datasheet Texas Instruments TPS27081ADDCR — Даташит
Серия | TPS27081A |
Модель | TPS27081ADDCR |
1,2 В - 8 В, 3 А PFET переключатель нагрузки высокого напряжения со сдвигом уровня и регулировкой скорости нарастания напряжения 6-SOT-23-THIN -40 to 85
TPS27081A 1.2-V to 8-V, 3-A PFET High-Side Load Switch With Level Shift and Adjustable Slew Rate Control datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 30 июн 2015
Pin | 6 |
Package Type | DDC |
Industry STD Term | SOT-23-THIN |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | AUA |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | .87 |
Pitch (мм) | .95 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Current Limit Type | None |
HBM ESD | 2 kV |
Imax | 3 A |
Количество каналов | 1 |
Output Rise Time @ 1.8V(Typ) | Adjustable us |
Overvoltage Protection | None |
Package Group | SOT-23-THIN |
Package Size: mm2:W x L | 6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG |
Quiescent Current (Iq)(Max) | 0.6 uA |
Quiescent Current (Iq)(Typ) | 0.03 uA |
Rating | Catalog |
Rise Time(Typ) | 0.253 us |
Ron @1.8V(Typ) | 82 mOhm |
Ron @4.5V(Typ) | 32 mOhm |
Ron(Typ) | 41 mOhm |
Shutdown Current (ISD)(Typ) | 0.05 uA |
Soft Start | Adjustable Rise Time |
Special Features | N/A |
UL Recognition | No |
Vin(Max) | 8 В |
Vin(Min) | 1.2 В |
- Reverse Battery Protection with the TPS27081APDF, 352 Кб, Файл опубликован: 7 июн 2016
In portable electronic equipment, there are many times throughout the lifetime of the device when the battery needs to be changed. Typically, there are indicators for the polarity of the battery, but if the battery is placed into the device incorrectly, it is possible that the electronic equipment could be permanently damaged. Adding protection circuitry can ensure that no damage occurs by disconn - Selecting a Load Switch to Replace a Discrete SolutionPDF, 624 Кб, Файл опубликован: 30 апр 2017
- Timing of Load SwitchesPDF, 171 Кб, Файл опубликован: 27 апр 2017
Серия: TPS27081A (1)
- TPS27081ADDCR
- Semiconductors > Power Management > Integrated Load Switches > Power Distribution & Savings
