Datasheet Texas Instruments TPS2H000AQPWPRQ1 — Даташит
Серия | TPS2H000-Q1 |
Модель | TPS2H000AQPWPRQ1 |
40-V/1000-mО© Dual Channels Smart High-Side Switch 16-HTSSOP -40 to 125
TPS2H000-Q1 40-V, 1000-mО© Dual-Channel Smart High-Side Power Switch datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 18 окт 2016
![]() 27 предложений от 13 поставщиков Импульсный источник питания, TEXAS INSTRUMENTS TPS2H000AQPWPRQ1 Power Load Distribution Switch IC, Active High, 2Outputs, 40V in, 1.6A, 1Ω, HTSSOP-16 New | |||
TPS2H000AQPWPRQ1 Texas Instruments | 211 ₽ | ||
TPS2H000AQPWPRQ1 Texas Instruments | 3 026 ₽ | ||
TPS2H000AQPWPRQ1 | 4 977 ₽ | ||
TPS2H000AQPWPRQ1 Texas Instruments | по запросу |
Pin | 16 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | 2H000AQ |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Current Limit Accuracy | +/-20%@0.1A |
Current Limit Type | Adjustable |
Current Sense Accuracy | +/-0.5mA@5mA +/-2.5mA@100mA |
Driver Configuration | High Side |
Input Threshold | CMOS,TTL |
Количество каналов | 2 |
Overvoltage Protection | None |
Package Group | HTSSOP |
Package Size: mm2:W x L | 16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG |
Rating | Automotive |
Ron @ 150C(Typ) | 2000 mOhms |
Ron @ 25C(Typ) | 1000 mOhms |
Shutdown Current (ISD)(Typ) | 0.5 uA |
Soft Start | None |
Special Features | Current Sense Output,Digital Output,Thermal Shutdown,Under Voltage Lock Out |
UL Recognition | No |
VCC(Max) | 40 В |
VCC(Min) | 3.4 В |
- Evaluation Modules & Boards: TPS2H000EVM
TPS2H000-Q1 Dual Channels Smart High-Side Switch Evaulation Module
- Adjustable Current Limit of Smart High-Side SwitchPDF, 400 Кб, Файл опубликован: 2 дек 2016
Adjustable current limit is a unique feature in Smart High Side Switch family from Texas Instruments. It is widely used to clamp the overload current, deliver the constant current and dynamically control the powerup inrush current.This application report introduces the principle and implementation of the function, and gives a guide on the set of the current limit value. It also provides som
Серия: TPS2H000-Q1 (2)
- TPS2H000AQPWPRQ1 TPS2H000BQPWPRQ1
- Semiconductors > Power Management > Integrated Load Switches > Smart High-Side Switches
