Источники питания Keen Side
Datasheet Texas Instruments TPS2H000BQPWPRQ1 — Даташит
СерияTPS2H000-Q1
МодельTPS2H000BQPWPRQ1
40-V/1000-mО© Dual Channels Smart High-Side Switch 16-HTSSOP -40 to 125
TPS2H000-Q1 40-V, 1000-mО© Dual-Channel Smart High-Side Power Switch datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 18 окт 2016
27 предложений от 13 поставщиков
Импульсный источник питания, TEXAS INSTRUMENTS TPS2H000BQPWPRQ1 Power Load Distribution Switch IC, Active High, 2Outputs, 40V in, 1.6A, 1Ω, HTSSOP-16 New
TPS2H000BQPWPRQ1
от 21 ₽
TPS2H000BQPWPRQ1
319 ₽
TPS2H000BQPWPRQ1
338 ₽
727GS
TPS2H000BQPWPRQ1
Pin16
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка2H000BQ
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Current Limit Accuracy+/-20%@0.1A
Current Limit TypeAdjustable
Current Sense Accuracy+/-0.5mA@5mA +/-2.5mA@100mA
Driver ConfigurationHigh Side
Input ThresholdCMOS,TTL
Количество каналов2
Overvoltage ProtectionNone
Package GroupHTSSOP
Package Size: mm2:W x L16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG
RatingAutomotive
Ron @ 150C(Typ)2000 mOhms
Ron @ 25C(Typ)1000 mOhms
Shutdown Current (ISD)(Typ)0.5 uA
Soft StartNone
Special FeaturesCurrent Sense Output,Digital Output,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionNo
VCC(Max)40 В
VCC(Min)3.4 В
  • Evaluation Modules & Boards: TPS2H000EVM
    TPS2H000-Q1 Dual Channels Smart High-Side Switch Evaulation Module
  • Adjustable Current Limit of Smart High-Side Switch
    PDF, 400 Кб, Файл опубликован: 2 дек 2016
    Adjustable current limit is a unique feature in Smart High Side Switch family from Texas Instruments. It is widely used to clamp the overload current, deliver the constant current and dynamically control the powerup inrush current.This application report introduces the principle and implementation of the function, and gives a guide on the set of the current limit value. It also provides som
Серия: TPS2H000-Q1 (2)
  • Semiconductors > Power Management > Integrated Load Switches > Smart High-Side Switches
На английском языке: Datasheet Texas Instruments TPS2H000BQPWPRQ1
