Datasheet Texas Instruments TPS2H160AQPWPRQ1 — Даташит
СерияTPS2H160-Q1
МодельTPS2H160AQPWPRQ1
40-V/160-mО© Dual Channels Smart High-Side Switch 16-HTSSOP -40 to 125
TPS2H160-Q1 40-V, 160-mО© Dual-Channel Smart High-Side Switch datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 15 авг 2016
Pin16
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка2H160AQ
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Current Limit Accuracy+/-15%@0.5A
Current Limit TypeAdjustable
Current Sense Accuracy+/-4.25mA@5mA
Driver ConfigurationHigh Side
Input ThresholdCMOS,TTL
Количество каналов2
Overvoltage ProtectionNone
Package GroupHTSSOP
Package Size: mm2:W x L16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG
RatingAutomotive
Ron @ 150C(Typ)280 mOhms
Ron @ 25C(Typ)155 mOhms
Shutdown Current (ISD)(Typ)0.5 uA
Soft StartNone
Special FeaturesCurrent Sense Output,Digital Output,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionNo
VCC(Max)40 В
VCC(Min)3.4 В
  • Evaluation Modules & Boards: TPS2H160EVM
    TPS2H160-Q1 Dual Channels Smart High-Side Switch Evaluation Module
  • Adjustable Current Limit of Smart High-Side Switch
    PDF, 400 Кб, Файл опубликован: 2 дек 2016
    Adjustable current limit is a unique feature in Smart High Side Switch family from Texas Instruments. It is widely used to clamp the overload current, deliver the constant current and dynamically control the powerup inrush current.This application report introduces the principle and implementation of the function, and gives a guide on the set of the current limit value. It also provides som
Серия: TPS2H160-Q1 (2)
  • Semiconductors > Power Management > Integrated Load Switches > Smart High-Side Switches
На английском языке: Datasheet Texas Instruments TPS2H160AQPWPRQ1
