Datasheet Texas Instruments TPS3103E15DBVTG4 — Даташит
| Серия | TPS3103 |
| Модель | TPS3103E15DBVTG4 |
Сверхнизкий ток питания, контрольные цепи напряжения 6-SOT-23 -40 до 85
TPS31xx Ultralow Supply-Current Voltage Monitor With Optional Watchdog datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 28 сен 2016
Купить TPS3103E15DBVTG4 на РадиоЛоцман.Цены — от 74 до 240 ₽16 предложений от 13 поставщиков Чип контроля напряжения, 1.434V Supply Voltage Supervisor 0V to 3.6V 1 Active Low/Open Drain 6Pin SOT-23 T/R | |||
| TPS3103E15DBVTG4 Texas Instruments | по запросу | ||
| Pin | 6 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | PFXI |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 2 |
| Iq(Typ) | 1.2 uA |
| Monitored Voltage 1 (typ)(Nom) | 1.2,1.5,2,3.3 В |
| Monitored Voltage 2 (typ)(Nom) | N/A В |
| Output Driver Type / Reset Output | Active-low,Open-drain |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rating | Catalog |
| Reset Threshold Accuracy | 1.5 % |
| Special Features | Active Low Enable,Manual Reset |
| Threshold Voltage 1(Typ) | 1.14,1.43,1.84,2.94 В |
| Threshold Voltage 2 (typ)(Typ) | N/A В |
| Time Delay | 130 ms |
| VCC(Max) | 3.6 В |
| VCC(Min) | 0.9 В |
| Watchdog Timer WDI | None sec |
- Monitoring Five Different Voltage Rails Using the TPS3103 and TPS3306PDF, 125 Кб, Файл опубликован: 28 авг 2003
As portable power designs get more complex, the number of power supply rails are increasing. Finding a simple supervisor circuit to monitor all the voltage rails can be complicated due to the number of different rail voltages and desired SVS trip voltages. To provide a solution for the more complex designs, the TPS3103 and TPS3306 can be used to monitor up to five different voltage rails. This des - Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: TPS3103 (16)
- Semiconductors > Power Management > Supervisor and Reset IC
