Datasheet Texas Instruments OPA129PB — Даташит
СерияOPA129
МодельOPA129PB
Операционный усилитель Difet со сверхнизким током смещения 8-PDIP
Ultra-Low Bias Current DifetВ® Operational Amplifier datasheet
PDF, 587 Кб, Версия: A, Файл опубликован: 28 апр 2007
7 предложений от 7 поставщиков
Микросхема Операционный усилитель, Op Amp Single GP ±18V 8Pin PDIP Tube
OPA129PB
OPA129PB
OPA129PB
727GS
OPA129PB
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementOPA129UB
Replacement CodeF
Additional FeaturesN/A
Approx. Price (US$)3.36 | 1ku
АрхитектураFET
CMRR(Min)(dB)80
CMRR(Typ)(dB)118
GBW(Typ)(MHz)1
Input Bias Current(Max)(pA)0.1
Iq per channel(Max)(mA)1.8
Iq per channel(Typ)(mA)1.2
Number of Channels(#)1
Offset Drift(Typ)(uV/C)3
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)35
Rail-to-RailNo
Slew Rate(Typ)(V/us)2.5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at 1kHz(Typ)(nV/rtHz)17
Vos (Offset Voltage @ 25C)(Max)(mV)2
RoHSНе совместим
  • Designing Photodiode Amplifier Circuits with OPA128
    The OPA128 ultra-low bias current operational amplifier achieves its 75fA maximum bias current without compromise. Using standard design techniques, serious performance trade-offs were required which sacrificed overall amplifier performance in order to reach femtoamp (fA = 10-15A) bias currents.
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA129PB
