Datasheet Texas Instruments TPS3306-18DGKRG4 — Даташит
| Серия | TPS3306 |
| Модель | TPS3306-18DGKRG4 |
Двухпроцессорная схема контроля с отключением питания и сторожевым таймером 8-VSSOP от -40 до 85
Dual-Processor Supervisory Circuits with Power-Fail datasheet
PDF, 841 Кб, Версия: C, Файл опубликован: 1 дек 2006
Купить TPS3306-18DGKRG4 на РадиоЛоцман.Цены — от 75 до 284 ₽13 предложений от 13 поставщиков Контрольный чип источника питания, Processor Supervisor 2.93V/1.68V 1.8V/3.3V 8Pin VSSOP T/R | |||
| TPS3306-18DGKRG4 Texas Instruments | 186 ₽ | ||
| TPS3306-18DGKRG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | AID |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 3 |
| Iq(Typ) | 15 uA |
| Monitored Voltage 1 (typ)(Nom) | 1.5,1.8,2,2.5,3.3,5 В |
| Monitored Voltage 2 (typ)(Nom) | N/A В |
| Output Driver Type / Reset Output | Active-low,Open-drain |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rating | Catalog |
| Reset Threshold Accuracy | 3.2 % |
| Special Features | Watchdog Timer |
| Threshold Voltage 1(Typ) | 1.4,1.68,1.85,2.25,2.93,4.55 В |
| Threshold Voltage 2 (typ)(Typ) | N/A В |
| Time Delay | 100 ms |
| VCC(Max) | 6 В |
| VCC(Min) | 2.7 В |
| Watchdog Timer WDI | 0.8 sec |
- Monitoring Five Different Voltage Rails Using the TPS3103 and TPS3306PDF, 125 Кб, Файл опубликован: 28 авг 2003
As portable power designs get more complex, the number of power supply rails are increasing. Finding a simple supervisor circuit to monitor all the voltage rails can be complicated due to the number of different rail voltages and desired SVS trip voltages. To provide a solution for the more complex designs, the TPS3103 and TPS3306 can be used to monitor up to five different voltage rails. This des - Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: TPS3306 (31)
- TPS3306-15D TPS3306-15DG4 TPS3306-15DGK TPS3306-15DGKG4 TPS3306-15DGKR TPS3306-15DGKRG4 TPS3306-15DR TPS3306-15DRG4 TPS3306-18D TPS3306-18DG4 TPS3306-18DGK TPS3306-18DGKG4 TPS3306-18DGKR TPS3306-18DGKRG4 TPS3306-18DR TPS3306-18DRG4 TPS3306-20D TPS3306-25D TPS3306-25DG4 TPS3306-25DGK TPS3306-25DGKG4 TPS3306-25DGKR TPS3306-25DGKRG4 TPS3306-25DR TPS3306-33D TPS3306-33DG4 TPS3306-33DGK TPS3306-33DGKG4 TPS3306-33DGKR TPS3306-33DGKRG4 TPS3306-33DR
- Semiconductors > Power Management > Supervisor and Reset IC
TPS330618DGKRG4, TPS3306 18DGKRG4
