Datasheet Texas Instruments TPS3306-33DGKR — Даташит
СерияTPS3306
МодельTPS3306-33DGKR
Двухпроцессорная схема контроля с отключением питания и сторожевым таймером 8-VSSOP от -40 до 85
Dual-Processor Supervisory Circuits with Power-Fail datasheet
PDF, 841 Кб, Версия: C, Файл опубликован: 1 дек 2006
Package TypeDGK
Industry STD TermVSSOP
Package QTY2500
МаркировкаAIG
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
# of Supplies Monitored3
Iq(Typ)15 uA
Monitored Voltage 1 (typ)(Nom)1.5,1.8,2,2.5,3.3,5 В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-low,Open-drain
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Reset Threshold Accuracy3.2 %
Special FeaturesWatchdog Timer
Threshold Voltage 1(Typ)1.4,1.68,1.85,2.25,2.93,4.55 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time Delay100 ms
VCC(Max)6 В
VCC(Min)2.7 В
Watchdog Timer WDI0.8 sec
  • Monitoring Five Different Voltage Rails Using the TPS3103 and TPS3306
    PDF, 125 Кб, Файл опубликован: 28 авг 2003
    As portable power designs get more complex, the number of power supply rails are increasing. Finding a simple supervisor circuit to monitor all the voltage rails can be complicated due to the number of different rail voltages and desired SVS trip voltages. To provide a solution for the more complex designs, the TPS3103 and TPS3306 can be used to monitor up to five different voltage rails. This des
  • Semiconductors > Power Management > Supervisor and Reset IC
TPS330633DGKR, TPS3306 33DGKR
На английском языке: Datasheet Texas Instruments TPS3306-33DGKR
