Datasheet Texas Instruments TPS3307-18DGNG4 — Даташит
Серия | TPS3307 |
Модель | TPS3307-18DGNG4 |
![Datasheet Texas Instruments TPS3307-18DGNG4](http://www.ti.com/graphics/folders/partimages/TPS3307.jpg)
Triple Processor Supervisory Circuit 8-MSOP-PowerPAD -40 to 85
Triple Processor Supervisors datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 1 дек 2006
![]() 18 предложений от 14 поставщиков Контрольные цепи Triple Processor Контрольные цепи | |||
TPS3307-18DGNG4 PBF, Микросхема Texas Instruments | 57 ₽ | ||
TPS3307-18DGNG4 Texas Instruments | 97 ₽ | ||
TPS3307-18DGNG4 Texas Instruments | 277 ₽ | ||
TPS3307-18DGNG4 Texas Instruments | от 563 ₽ |
Pin | 8 |
Package Type | DGN |
Industry STD Term | HVSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 80 |
Carrier | TUBE |
Маркировка | AAP |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
# of Supplies Monitored | 3 |
Iq(Typ) | 40 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable,1.8,2.5,3.3,5 В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Output Driver Type / Reset Output | Active-low,Push-pull |
Package Group | MSOP-PowerPAD |
Package Size: mm2:W x L | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 3.2 % |
Special Features | Active Low Enable,Manual Reset |
Threshold Voltage 1(Typ) | Adjustable,1.68,2.25,2.93,4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 200 ms |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Watchdog Timer WDI | None sec |
- CAN Design White PaperPDF, 234 Кб, Файл опубликован: 10 фев 2004
Серия: TPS3307 (24)
- TPS3307-18D TPS3307-18DG4 TPS3307-18DGN TPS3307-18DGNG4 TPS3307-18DGNR TPS3307-18DGNRG4 TPS3307-18DR TPS3307-18DRG4 TPS3307-25D TPS3307-25DG4 TPS3307-25DGN TPS3307-25DGNG4 TPS3307-25DGNR TPS3307-25DGNRG4 TPS3307-25DR TPS3307-25DRG4 TPS3307-33D TPS3307-33DG4 TPS3307-33DGN TPS3307-33DGNG4 TPS3307-33DGNR TPS3307-33DGNRG4 TPS3307-33DR TPS3307-33DRG4
- Semiconductors > Power Management > Supervisor and Reset IC
TPS330718DGNG4, TPS3307 18DGNG4
