Datasheet Texas Instruments TPS3606-33DGSR — Даташит
Серия | TPS3606-33 |
Модель | TPS3606-33DGSR |
Battery-Backup Supervisor for Low Power Processor 10-VSSOP -40 to 85
Battery-Backup Supervisor for Low-Power Processors datasheet
PDF, 507 Кб, Версия: C, Файл опубликован: 9 янв 2007
Купить TPS3606-33DGSR на РадиоЛоцман.Цены — от 148 до 1 213 ₽ 12 предложений от 9 поставщиков Supervisor Push-Pull, Totem Pole 1 Channel 10-VSSOP | |||
TPS3606-33DGSR Texas Instruments | 148 ₽ | ||
TPS3606-33DGSR Texas Instruments | 203 ₽ | ||
TPS3606-33DGSR Texas Instruments | 622 ₽ | ||
TPS3606-33DGSR Texas Instruments | по запросу |
Pin | 10 |
Package Type | DGS |
Industry STD Term | VSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | AKE |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .5 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 20 uA |
Monitored Voltage 1 (typ)(Nom) | 3.3 В |
Monitored Voltage 2 (typ)(Nom) | Adjustable В |
Output Driver Type / Reset Output | Active-low,Push-pull |
Package Group | VSSOP |
Package Size: mm2:W x L | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2 % |
Special Features | Active Low Enable,Battery Backup Switchover,Manual Reset,Watchdog Timer |
Threshold Voltage 1(Typ) | 2.93 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 100 ms |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Watchdog Timer WDI | 0.8 sec |
- Evaluation Modules & Boards: TPS3600EVM-186
TPS3600EVM-186 Evaluation Module
- Disabling the Watchdog Timer for TI's Family of SupervisorsPDF, 138 Кб, Файл опубликован: 30 окт 2003
In many microprocessor applications where a watchdog supervisor, such as the TPS3306, is required, it may be necessary to disable the watchdog. This is particularly true when software boot times exceed the watchdog time-out period. This application note describes a circuit that can be used to selectively disable the watchdog timer. - Using the TPS3619 with MSP430 Microcontrollers Can Reduce Sys Power Consumption (Rev. A)PDF, 37 Кб, Версия: A, Файл опубликован: 19 май 2003
The MSP430 series of microcontrollers are ideal in applications where battery life is critical. These microcontollers require only 0.1?A of current in low-power RAM retention mode; In this mode the microcontroller must have power to retain volatile memory. In some systems with charge pumps, the TPS3619 can be used to shut down the charge pump, saving system power consumption. - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
Серия: TPS3606-33 (4)
- TPS3606-33DGS TPS3606-33DGSG4 TPS3606-33DGSR TPS3606-33DGSRG4
- Semiconductors > Power Management > Supervisor and Reset IC
TPS360633DGSR, TPS3606 33DGSR
