Datasheet Texas Instruments TPS3617-50DGKG4 — Даташит
Серия | TPS3617-50 |
Модель | TPS3617-50DGKG4 |
Battery-Backup Supervisors for RAM Retention 8-VSSOP -40 to 85
Battery-Backup Supervisor for RAM Retention datasheet
PDF, 818 Кб, Версия: D, Файл опубликован: 10 дек 2006
Купить TPS3617-50DGKG4 на РадиоЛоцман.Цены — от 137 до 266 ₽ 12 предложений от 9 поставщиков new in stock for immediate delivery | |||
TPS3617-50DGKG4 Texas Instruments | от 137 ₽ | ||
TPS3617-50DGKG4 Texas Instruments | 146 ₽ | ||
TPS3617-50DGKG4 Texas Instruments | 153 ₽ | ||
TPS3617-50DGKG4 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 80 |
Carrier | TUBE |
Маркировка | ASD |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 20 uA |
Monitored Voltage 1 (typ)(Nom) | 5 В |
Monitored Voltage 2 (typ)(Nom) | Adjustable В |
Output Driver Type / Reset Output | Active-low,Push-pull |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2 % |
Special Features | Battery Backup Switchover,Watchdog Timer |
Threshold Voltage 1(Typ) | 4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | 100 ms |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Watchdog Timer WDI | 0.8 sec |
- Disabling the Watchdog Timer for TI's Family of SupervisorsPDF, 138 Кб, Файл опубликован: 30 окт 2003
In many microprocessor applications where a watchdog supervisor, such as the TPS3306, is required, it may be necessary to disable the watchdog. This is particularly true when software boot times exceed the watchdog time-out period. This application note describes a circuit that can be used to selectively disable the watchdog timer. - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
Серия: TPS3617-50 (3)
- TPS3617-50DGK TPS3617-50DGKG4 TPS3617-50DGKR
- Semiconductors > Power Management > Supervisor and Reset IC
TPS361750DGKG4, TPS3617 50DGKG4
