Datasheet Texas Instruments TPS3700DSER — Даташит
СерияTPS3700
МодельTPS3700DSER
Высоковольтный (18 В) оконный детектор напряжения для контроля повышенного и пониженного напряжения 6-WSON -40 до 125
Pin66
Package TypeDSEDSE
Industry STD TermWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка7IBE
Width (мм)1.51.5
Length (мм)1.51.5
Thickness (мм)0.750.75
Pitch (мм)0.50.5
Max Height (мм)0.80.8
Approx. price0.61 | 1ku US$
Основные особенностиUndervoltage and overvoltage monitor,Wide input voltage,Dual output
Iq(Typ)5.5 uA
Monitored voltage 1 (typ)(Nom)Adjustable В
Number of supplies monitored1,2
Operating temperature range-40 to 125 C
Output driver type/reset outputActive-low,Open-drain
Package GroupSOT-23-THIN|6,WSON|6
Package size: mm2:W x L6SOT-23-THIN: 5 mm2: 1.6 x 2.9 (SOT-23-THIN|6),6WSON: 2 mm2: 1.5 x 1.5 (WSON|6) PKG
Reset threshold accuracy1 %
Supply voltage(Max)18 В
Supply voltage(Min)1.8 В
Threshold voltage 1(Typ)Adjustable В
Watchdog timer WDINone sec
  • Evaluation boards: ISO5852SDWEVM-017
    Driving and Protection Evaluation Board for SiC and IGBT Power Modules
  • Evaluation boards: UCC21750QDWEVM-025
    Driving and protection evaluation board for SiC and IGBT transistors and power modules
  • Evaluation boards: UCC21732QDWEVM-025
  • Evaluation boards: TPS3700EVM-114
    TPS3700 high-voltage (18-V) window voltage detector evaluation module for SOT-23 package
  • Evaluation boards: TPS3700EVM-202
    TPS3700 high-voltage (18-V) window voltage detector evaluation module for WSON package
  • Semiconductors > Analog and Mixed-Signal > Power management > Supervisor & reset ICs
На английском языке: Datasheet Texas Instruments TPS3700DSER
