Datasheet Texas Instruments TPS3805H33DCKR — Даташит
СерияTPS3805H33
МодельTPS3805H33DCKR
Двойной детектор напряжения 5-SC70 -40 до 85
Voltage Detector datasheet
PDF, 913 Кб, Версия: A, Файл опубликован: 26 июн 2007
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаAWK
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
# of Supplies Monitored2
Iq(Typ)3 uA
Monitored Voltage 1 (typ)(Nom)3.3 В
Monitored Voltage 2 (typ)(Nom)Adjustable В
Output Driver Type / Reset OutputActive-low,Push-pull
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Reset Threshold Accuracy1.5 %
Threshold Voltage 1(Typ)3.05 В
Threshold Voltage 2 (typ)(Typ)Adjustable В
VCC(Max)6 В
VCC(Min)1.3 В
Watchdog Timer WDINone sec
  • TPS3801/09 - Smallest SVS for Monitoring DSPs and Processors
    PDF, 185 Кб, Файл опубликован: 2 сен 1999
    This application report describes the TPS3801 and TPS3809 supply voltage supervisor (SVS) families of devices. The report gives a general introduction to reset generators followed by an overview of the technical parameters and the special features of the TPS380x. Each feature is discussed separately. Measurements make it easy to understand SVS principles of operation. Typical applications that inc
Серия: TPS3805H33 (2)
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TPS3805H33DCKR
