Datasheet Texas Instruments TPS3808G30DRVT — Даташит
СерияTPS3808
МодельTPS3808G30DRVT
Схема контроля с низким током покоя, программируемой задержкой 6-WSON от -40 до 125
TPS3808 Low-Quiescent-Current, Programmable-Delay Supervisory Circuit datasheet
PDF, 1.1 Мб, Версия: K, Файл опубликован: 16 окт 2015
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаAVP
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
# of Supplies Monitored1
Iq(Typ)2.4 uA
Monitored Voltage 1 (typ)(Nom)Adjustable,0.9,1.2,1.25,1.5,1.8,1.9,2.5,3,3.3,5 В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-low,Open-drain
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Reset Threshold Accuracy2 %
Special FeaturesActive Low Enable,Manual Reset
Threshold Voltage 1(Typ)Adjustable,0.84,1.12,1.16,1.4,1.67,1.77,2.33,2.79,3.07,4.65 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)6.5 В
VCC(Min)1.8 В
Watchdog Timer WDINone sec
  • Evaluation Modules & Boards: TDP158RSBEVM
    6 Gbps AC Coupled to TMDSВ™/HDMIВ™ Redriver Evaluation Module
  • Evaluation Modules & Boards: SN65DSI85EVM
    SN65DSI85 Dual-Channel MIPIВ® DSI to Dual-Link FlatLinkВ™ LVDS Bridge Evaluation Module
  • Evaluation Modules & Boards: SN65DSI85Q1-EVM
  • Evaluation Modules & Boards: SN65DSI83Q1-EVM
    MIPIВ® DSI to FlatLinkВ™ LVDS Bridge Evaluation Module
  • Setting the SVS Voltage Monitor Threshold
    PDF, 88 Кб, Файл опубликован: 23 май 2012
  • Power Two Xilinx(TM) LX240 Virtex-6(TM) Devices
    PDF, 63 Кб, Файл опубликован: 20 апр 2010
    This reference design is intended to help designers wishing to use two of the new Virtex-6™ LX240 FPGA along with DDR memory and other optional circuitry in their designs. It provides nine rails of lower voltage with an input of 12 volts. The use of PTH T2 modules provides a high-performance solution for good transient response and tight regulation while conserving valuable board space.
  • Recommended Power Solutions for the TMS320x2810/1/2 DSPs
    PDF, 28 Кб, Файл опубликован: 31 янв 2005
    This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application.
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TPS3808G30DRVT
