Datasheet Texas Instruments TPS3824-30DBVTG4 — Даташит
| Серия | TPS3824 |
| Модель | TPS3824-30DBVTG4 |
Монитор напряжения со сторожевым таймером 5-SOT-23
TPS382x Voltage Monitor With Watchdog Timer datasheet
PDF, 929 Кб, Версия: K, Файл опубликован: 17 сен 2014
Купить TPS3824-30DBVTG4 на РадиоЛоцман.Цены — от 28 до 86 ₽10 предложений от 10 поставщиков Чип контроля напряжения, Processor Supervisor 2.63V 0V to 5.8V 5Pin SOT-23 T/R | |||
| TPS3824-30DBVTG4 Texas Instruments | 41 ₽ | ||
| TPS3824-30DBVTG4 Texas Instruments | 67 ₽ | ||
| TPS3824-30DBVTG4 | по запросу | ||
| TPS3824-30DBVTG4 Texas Instruments | по запросу | ||
| Pin | 5 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | PAUI |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 1 |
| Iq(Typ) | 15 uA |
| Monitored Voltage 1 (typ)(Nom) | 2.5,3,3.3,5 В |
| Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rating | Catalog |
| Reset Threshold Accuracy | 2.4 % |
| Special Features | Watchdog Timer |
| Threshold Voltage 1(Typ) | 2.25,2.63,2.93,4.55 В |
| Time Delay | 200 ms |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.1 В |
| Watchdog Timer WDI | 1.6 sec |
- Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
Серия: TPS3824 (16)
- Semiconductors > Power Management > Supervisor and Reset IC
TPS382430DBVTG4, TPS3824 30DBVTG4
