Datasheet Texas Instruments TPS3824-50DBVTG4 — Даташит
СерияTPS3824
МодельTPS3824-50DBVTG4
Монитор напряжения со сторожевым таймером 5-SOT-23
TPS382x Voltage Monitor With Watchdog Timer datasheet
PDF, 929 Кб, Версия: K, Файл опубликован: 17 сен 2014
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаPAWI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# of Supplies Monitored1
Iq(Typ)15 uA
Monitored Voltage 1 (typ)(Nom)2.5,3,3.3,5 В
Output Driver Type / Reset OutputActive-high,Active-low,Push-pull
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Reset Threshold Accuracy2.4 %
Special FeaturesWatchdog Timer
Threshold Voltage 1(Typ)2.25,2.63,2.93,4.55 В
Time Delay200 ms
VCC(Max)5.5 В
VCC(Min)1.1 В
Watchdog Timer WDI1.6 sec
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Semiconductors > Power Management > Supervisor and Reset IC
TPS382450DBVTG4, TPS3824 50DBVTG4
На английском языке: Datasheet Texas Instruments TPS3824-50DBVTG4
