Datasheet Texas Instruments TPS389018QDSERQ1 — Даташит
Серия | TPS3890-Q1 |
Модель | TPS389018QDSERQ1 |
Автомобильный низкий ток покоя, точность 1% супервизор с программируемой задержкой 6-WSON -40 до 125
TPS3890-Q1 Low Quiescent Current, 1% Accurate Supervisor with Programmable Delay datasheet
PDF, 1.0 Мб, Файл опубликован: 9 мар 2017
![]() 21 предложений от 12 поставщиков , Automotive Low Quiescent Current, 1% Accurate Supervisor With Programmable Delay 6-WSON -40℃ to 125℃ | |||
TPS389018QDSERQ1 Texas Instruments | 23 ₽ | ||
TPS389018QDSERQ1 Texas Instruments | 70 ₽ | ||
TPS389018QDSERQ1 Texas Instruments | от 188 ₽ | ||
TPS389018QDSERQ1 Texas Instruments | 189 ₽ |
Pin | 6 |
Package Type | DSE |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 2Q |
Width (мм) | 1.5 |
Length (мм) | 1.5 |
Thickness (мм) | .75 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 2.1 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable,1.2,1.5,1.8,2.5,3,3.3 В |
Output Driver Type / Reset Output | Active-low,Open-drain |
Package Group | WSON |
Package Size: mm2:W x L | See datasheet (WSON) PKG |
Rating | Automotive |
Reset Threshold Accuracy | 1 % |
Special Features | Active Low Enable,Manual Reset |
Threshold Voltage 1(Typ) | Adjustable,1.15,1.44,1.73,1.9,2.4,2.89,3.17 В |
Time Delay | Programmable ms |
VCC(Max) | 5.5 В |
VCC(Min) | 1.5 В |
Watchdog Timer WDI | None sec |
- Evaluation Modules & Boards: TPS3890EVM-775
TPS3890 Low Quiescent Current, 1% Accurate Supervisor With Programmable Delay Evaluation Module
Серия: TPS3890-Q1 (7)
- Semiconductors > Power Management > Supervisor and Reset IC
