Datasheet Texas Instruments TPS4H000BQPWPRQ1 — Даташит
СерияTPS4H000-Q1
МодельTPS4H000BQPWPRQ1
40-V/1000-mО© Quad Channels Smart High-Side Switch 20-HTSSOP -40 to 125
TPS4H000-Q1 40-V, 1000-mО© Quad-Channel Smart High-Side Switch datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 31 окт 2016
Pin20
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка4H000BQ
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Current Limit Accuracy+/-20%@0.1A
Current Limit TypeAdjustable
Current Sense Accuracy+/-0.75mA@5mA +/-3mA@100mA
Driver ConfigurationHigh Side
Input ThresholdCMOS,TTL
Количество каналов4
Overvoltage ProtectionNone
Package GroupHTSSOP
Package Size: mm2:W x L20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG
RatingAutomotive
Ron @ 150C(Typ)2000 mOhms
Ron @ 25C(Typ)1000 mOhms
Shutdown Current (ISD)(Typ)0.5 uA
Soft StartNone
Special FeaturesCurrent Sense Output,Digital Output,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionNo
VCC(Max)40 В
VCC(Min)3.4 В
  • Evaluation Modules & Boards: TPS4H000EVM
    TPS4H000-Q1 Quad Channels Smart High-Side Switch Evaluaion Module
  • Adjustable Current Limit of Smart High-Side Switch
    PDF, 400 Кб, Файл опубликован: 2 дек 2016
    Adjustable current limit is a unique feature in Smart High Side Switch family from Texas Instruments. It is widely used to clamp the overload current, deliver the constant current and dynamically control the powerup inrush current.This application report introduces the principle and implementation of the function, and gives a guide on the set of the current limit value. It also provides som
Серия: TPS4H000-Q1 (2)
  • Semiconductors > Power Management > Integrated Load Switches > Smart High-Side Switches
На английском языке: Datasheet Texas Instruments TPS4H000BQPWPRQ1
