Datasheet Texas Instruments TPS54308DDCT — Даташит
СерияTPS54308
МодельTPS54308DDCT
Вход 4,5 В - 28 В, выход 3 А, синхронный понижающий преобразователь FCCM 350 кГц 6-SOT-23-THIN -40 в 125
TPS54308 4.5-V to 28-V Input, 3-A Output, Synchronous 350-kHz FCCM Step-Down Converter in SOT23 Package datasheet
PDF, 1.2 Мб, Файл опубликован: 23 янв 2017
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY250
CarrierSMALL T&R
Маркировка4308
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Iout(Max)3 A
Iq(Typ)0.3 мА
Package GroupSOT-23-THIN
Regulated Outputs1
Special FeaturesEnable,Pre-Bias Start-Up,Synchronous Rectification,UVLO Adjustable
Switching Frequency(Max)350 kHz
Switching Frequency(Min)350 kHz
Switching Frequency(Typ)350 kHz
ТипConverter
Vin(Max)28 В
Vin(Min)4.5 В
Vout(Max)26 В
Vout(Min)1 В
  • Evaluation Modules & Boards: TPS54308EVM-876
    TPS54308 4.5V to 28V Input, 3A Output Synchronous Step-Down Converter Evaluation Module
  • Designing a Simple and Low-Cost Flybuck Solution With the TPS54308
    PDF, 1.3 Мб, Файл опубликован: 29 авг 2017
    In many applications, simple, low part-count, isolated power supplies working from an input voltage are needed. A popular solution to these requirements is an isolated buck power supply. This application report presents a simple and low-cost flybuck solution using the TPS54308 device. The basic operating principles of a flybuck converter are discussed, operating current and voltage waveforms are s
Серия: TPS54308 (2)
На английском языке: Datasheet Texas Instruments TPS54308DDCT
