Datasheet Texas Instruments OPA603AP — Даташит
| Серия | OPA603 |
| Модель | OPA603AP |
Высокоскоростной операционный усилитель с токовой обратной связью 8-PDIP
Купить OPA603AP на РадиоЛоцман.Цены — от 42 до 4 080 ₽9 предложений от 9 поставщиков Быстродействующие операционные усилители DIP-8 High-Speed Cu | |||
| OPA603AP | 1 571 ₽ | ||
| OPA603AP | по запросу | ||
| OPA603AP Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Evaluation Modules & Boards: DEM-OPA68XP
DEM-OPA68xP: Demonstration Fixture
- Voltage-Feedback Amps vs Current-Feedback Amps: Bandwidth and DistortionPDF, 33 Кб, Файл опубликован: 27 сен 2000
Current-feedback amplifiers have nearly constant bandwidth for varying closed-loop gains. The reason is that the user can adjust the open-loop gain of the current-feedback amplifier by changing the feedback network without affecting the open-loop pole. - Composite Op Amp Gives You The Best of Both WorldsPDF, 32 Кб, Файл опубликован: 27 сен 2000
Classical op amps such as the OPA627 have excellent performance in applications where the required gain bandwidth is low compared to the gain-bandwidth product of the op amp. However, increasing closed-loop gain decreases the error-reducing loop gain. Furthermore, starting at relatively low frequencies, the loop gain rolls-off at 20dB/decade of signal frequency increase. In combination these effec - The Current-Feedback Op Amp: A High-Speed Building BlockPDF, 117 Кб, Файл опубликован: 2 окт 2000
Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: OPA603 (3)
- OPA603AP OPA603AU OPA603AU/1K
