Datasheet ТI TPS61253AYFFR — Даташит
| Серия | TPS61253A |
| Модель | TPS61253AYFFR |
3,8 МГц, 5 В / 4 А, усиление в 1,2 мм x 1,3 мм WCSP 9-DSBGA -40 до 85
TPS61253A 3.8-MHz, 5-V / 4-A Boost Converter in 1.2-mm x 1.3-mm WCSP datasheet
PDF, 1.5 Мб, Файл опубликован: 27 янв 2016
- Choosing the Boost With Bypass or Pass ThroughPDF, 311 Кб, Файл опубликован: 27 июн 2017
For some applications – smart phones, radio-frequency power amplifiers (RF PA), and USB connectors,for example – the load requires a higher voltage to operate than the minimum voltage. The conventionalboost converter outputs greater voltage than the input voltage but cannot handle inputs that swing abovethe desired output. New topologies combining a boost converter plus a bypass switch or bo
Серия: TPS61253A (2)
- TPS61253AYFFR TPS61253AYFFT
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
