Datasheet Texas Instruments TPS65010RGZTG4 — Даташит
Серия | TPS65010 |
Модель | TPS65010RGZTG4 |
Многоканальное зарядное устройство с 1 ячейкой Li-Ion PMIC USB/AC, 2DC/DC, 2 LDO, интерфейс I2C в QFN-48 48-VQFN
TPS65010 Power and Battery Management IC for Li-Ion Powered Systems datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 30 сен 2015
Pin | 48 |
Package Type | RGZ |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | TPS65010 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Iout(Max) | 1 A |
Iq(Typ) | 0.07 мА |
LDO | 2 |
Package Group | VQFN |
Package Size: mm2:W x L | 48VQFN: 49 mm2: 7 x 7(VQFN) PKG |
Rating | Catalog |
Regulated Outputs | 4 |
Special Features | Power Good |
Step-Down DC/DC Converter | 2 |
Switching Frequency(Max) | 1500 kHz |
Vin(Max) | 6.5 В |
Vin(Min) | 1.8 В |
Vout(Max) | 6.5 В |
Vout(Min) | 0.85 В |
- Evaluation Modules & Boards: TPS65010EVM-230
TPS65010 Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TPS65011EVM-049
TPS65011 Evaluation Module
- TPS6501x Device Comparison (Rev. B)PDF, 68 Кб, Версия: B, Файл опубликован: 12 июл 2005
This application report presents an overview on the differences among the TPS6501x family members. Devices included are the TPS65010, TPS65011, TPS65012,TPS65013, and TPS65014. It is intended to assist design engineers in selecting the most suitable device for their applications. - OMAP5910 Low-Power System Design (Rev. A)PDF, 309 Кб, Версия: A, Файл опубликован: 25 мар 2004
The OMAP5910 is a true system-on-a-chip device, which consists of ARM925T MPU and C55X DSP cores. The device has many advanced power management modes that enable system designers to develop a very low-power, multimedia communication device. This application note shows low-power design techniques and outlines the steps required to put the OMAPв„ў device in the lowest power consumption mode and - Understanding the TPS65010 SoftwarePDF, 548 Кб, Файл опубликован: 17 ноя 2003
The TPS65010 is an integrated, extremely versatile IC. It contains a Li-Ion battery charger,two switching regulators, two linear regulators, two LED drivers, a motor driver, 4 GPIOs, and an assortment of control and status bits. All outputs are configurable by an external processor via an I2C bus. The TPS65010 contains sixteen 8-bit registers that both control the functions of the IC as well as re - Selecting the correct IC for power-supply applicationsPDF, 184 Кб, Файл опубликован: 14 дек 2006
- Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
Серия: TPS65010 (4)
- TPS65010RGZR TPS65010RGZRG4 TPS65010RGZT TPS65010RGZTG4
- Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
