Datasheet Texas Instruments TPS65020RHARG4 — Даташит
Серия | TPS65020 |
Модель | TPS65020RHARG4 |
6-Channel Power Management IC (PMIC) with 3DC/DCs, 3 LDOs, I2C interface and Dynamic Voltage Scaling 40-VQFN -40 to 85
TPS65020 Power Management IC For Li-Ion or Li-Polymer Powered Systems datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 8 янв 2016
Купить TPS65020RHARG4 на РадиоЛоцман.Цены — от 244 до 1 337 ₽ 12 предложений от 9 поставщиков Battery Power Management IC Lithium Ion/Polymer 40-VQFN (6x6) | |||
TPS65020RHARG4 Texas Instruments | 244 ₽ | ||
TPS65020RHARG4 Texas Instruments | 383 ₽ | ||
TPS65020RHARG4 Texas Instruments | 506 ₽ | ||
TPS65020RHARG4 Texas Instruments | 510 ₽ |
Pin | 40 | 40 |
Package Type | RHA | RHA |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 65020 | TPS |
Width (мм) | 6 | 6 |
Length (мм) | 6 | 6 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Iout(Max) | 1.2 A |
Iq(Typ) | 0.085 мА |
LDO | 3 |
Package Group | VQFN |
Package Size: mm2:W x L | 40VQFN: 36 mm2: 6 x 6(VQFN) PKG |
Processor Name | PXA270 |
Processor Supplier | Marvell |
Rating | Catalog |
Regulated Outputs | 6 |
Special Features | Comm Control,Power Good,Power Sequencing |
Step-Down DC/DC Converter | 3 |
Vin(Max) | 6.5 В |
Vin(Min) | 1.5 В |
Vout(Max) | 6 В |
Vout(Min) | 0.6 В |
- Evaluation Modules & Boards: TPS65020EVM-110
TPS65020 Evaluation Module
- Differences Between TPS65020/021/022PDF, 32 Кб, Файл опубликован: 25 июл 2006
- Understanding the TPS65010 SoftwarePDF, 548 Кб, Файл опубликован: 17 ноя 2003
The TPS65010 is an integrated, extremely versatile IC. It contains a Li-Ion battery charger,two switching regulators, two linear regulators, two LED drivers, a motor driver, 4 GPIOs, and an assortment of control and status bits. All outputs are configurable by an external processor via an I2C bus. The TPS65010 contains sixteen 8-bit registers that both control the functions of the IC as well as re - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TPS65020 (4)
- TPS65020RHAR TPS65020RHARG4 TPS65020RHAT TPS65020RHATG4
- Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
